Introduzione
Use this guide to replace your Shuffle's battery. Replacing the battery requires a fine-tipped soldering iron and knowledge of surface-mount soldering.
Before beginning, be sure your Shuffle is turned off as shown.
  • Before beginning, be sure your Shuffle is turned off as shown.
Aggiungi Commento
Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle. Remove the plastic cover and set it aside.
  • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
  • Remove the plastic cover and set it aside.
Aggiungi Commento
Remove the two Phillips screws from the headphone jack side of the Shuffle.
  • Remove the two Phillips screws from the headphone jack side of the Shuffle.
Aggiungi Commento
Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle. Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
  • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
Aggiungi Commento
Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle. Remove the plastic cover and set it aside.
  • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
Aggiungi Commento
Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle. Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
  • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
Thanks for this great instruction. Little note: Not important for the function, but contrary to the images the green side of the on/off-slider originally must point in the opposite (inner) direction.
Martin - Replica
Remove the two Phillips screws on the controls side of the Shuffle.
  • Remove the two Phillips screws on the controls side of the Shuffle.
Aggiungi Commento
Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle. Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
  • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
Aggiungi Commento
Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
  • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
Aggiungi Commento
Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges. Pull the logic board assembly out of the outer case.
  • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
  • Pull the logic board assembly out of the outer case.
Aggiungi Commento
Use the edge of an iPod opening tool to peel the adhesive under the battery that secures it to the logic board. Flip the battery upwards to reveal the solder pads soldered to the logic board.
  • Use the edge of an iPod opening tool to peel the adhesive under the battery that secures it to the logic board.
  • Flip the battery upwards to reveal the solder pads soldered to the logic board.
  • Before desoldering the battery, be sure to scrape the protective resin off both solder points.
  • Desolder the battery from the logic board by heating up the solder joint with a soldering iron and simultaneously using a pair of tweezers to pull the battery wire away from the logic board.
  • Do not touch the + and - leads together.
  • If you have never soldered before, we have a guide that makes it easy.
Using the Soldering tip to heat the resin covering the Battery Wire Connections will allow easy removal of the Resin Covering Without Damageing the Logic Board with Scraping.
lloyd193 - Replica
Battery is Lithium 3.7 volt 100-120 mA dimensions 3mm x 23mm x 23mm
Search on eBay for 3.7 v 032323
chi tran - Replica
Conclusione
Altre 46 persone hanno completato questa guida.
Followed your clear instructions and made a successful battery change. It would be helpful to explain that both cover plates are held ond by double sided sticky tape and to give caution on the location of the miniclips on the control cover - I cut through 2 of them by mistake. Thanks for the help.
Regards, Frank, North yorkshire, UK
FrankF - Replica
I rarely find instructions so detailed and foolproof. I ended up with a "new" iPod saving a bunch of money.
Read on about the incidents I encountered.
The working end of the plastic pry tool snapped off rendering it useless, but not before it irreparably bent the pink housing. The suggested screwdriver for which I paid extra did not undo the tiny screws, and I eventually tapped them out with a miniscule eyeglass-repair screwdriver. (Is it a coincidence I did not see a screwdriver in any of the photos?)
Ditto on the suggestion that the super-sticky adhesive presents itself as an obstacle. A suggestion to apply pressure slowly as the adhesive releases would have been helpful.
robinondeck - Replica
I loved that the instructions were really easy to follow. It would be helpful to mention that the logic board ought to be really carefully pushed out. It was difficult in my case and I had to apply a considerable amount of force to slowly push it out.
Despite taking care to control my strength and push it out, part of the protective yellow tape got torn and one of the components was dislodged and broken. It must've been pretty important cuz unfortunately my iPod didn't work after I put it together in one piece. I'm sure the fault lies in my carelessness, the instructions were great. I hope you guys have better luck with yours (:
Jane - Replica
just to add what Frank said: the white plastic control cover has 6 tiny clips; two either side of the sliding switches and two in the middle. I found that gently levering the cover up by inserting the tip of an Xacto blade through the holes the sliders ride in avoids damaging the clips. Be careful not to turn the iPod on when you do this or scratch the green paint next to the on/off slider.
James - Replica
Does anyone have what the best approach to removing the resin from the solder points?
Matt Rausch - Replica
To remove the resin use a Q-tip and some solvent.
Rick - Replica
We followed the instructions, it worked!!
I scraped the epoxy off of the solder points with the end of the #00 screwdriver (using it like a file).
My FIL did the soldering, with a big blunt tip, he's amazing.
Thank you!!
Running Around - Replica
Do you know anyone who will perform this process for me? Also, is it still possible to get batteries for the 2nd generation Ipod shuffles?
burt34 - Replica
Really.. I am thankful to you (Andrew Bookholt), Also it would be more helpful if you mention the link where the original battery will be available.
Senthilvelan K - Replica
Mine had no clips at the plastic control cover because it was glued to the metal stripes with double-sided adhesive tape. It tooks a while until I realized this but I didn't damage something. I used a thin piece of metal, to separate the plastic cover from the metal stripes.
Andreas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 38
Ultimi 7 Giorni: 181
Ultimi 30 Giorni: 1,015
Tutti i Tempi: 125,216
