Introduzione
Use this guide to replace your Nano's logic board assembly.
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
  • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
  • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
Aggiungi Commento
While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
  • While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
  • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
  • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
  • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
I strongly recommend using a Small Suction Cup (IF145-019-1) instead of a plastic opening tool.
After half an hour of various heating times, trying to use a plastic opening tool, I overheated the LCD, which caused it to discolour. Now I need to buy a new screen. I wish I'd thought to use a suction cup earlier; it seems so obvious in retrospect.
Peter Burkimsher - Replica
Lift the front panel assembly from the headphone jack side of the Nano. Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
  • Lift the front panel assembly from the headphone jack side of the Nano.
  • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
  • The front panel assembly is still attached to the Nano by two cables.
Aggiungi Commento
Lay the front panel assembly next to the Nano.
  • Lay the front panel assembly next to the Nano.
  • Remove the following two screws:
    • One 2.3 mm Phillips screw
    • One 2.6 mm shouldered Phillips screw
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Use an iPod opening tool to pry the steel shield out of the Nano by its upper right corner. Remove the steel shield from the Nano.
  • Use an iPod opening tool to pry the steel shield out of the Nano by its upper right corner.
  • Remove the steel shield from the Nano.
Aggiungi Commento
Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board. Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
  • Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
Aggiungi Commento
Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
  • Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
How come you did not put back the metal plate that goes between the iPod and the display?
Adam Meyerson - Replica
You do put the steel shield back in to place and screw it down, but only after you connect the digitizer and display data cable connectors to their sockets on the logic board.
Lance J - Replica
Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
  • Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Hello.. I lost my jack connector and it still stay on logic board.. So what will i do? I cant remove it from logic board.. Please help me.. :(
Emonk - Replica
Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
  • Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
Aggiungi Commento
Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case. The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
  • Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
    • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
  • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
Aggiungi Commento
Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
  • Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
  • Do not excessively pry the logic board upward.
Aggiungi Commento
Use your iPod opening tool to gently push the dock connector toward the center of the Nano. Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
  • Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
  • Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
very good directions. You lead only half way to the push button area. I have to try the rest of the way!
Good work!
kcryeung - Replica
Conclusione
Altre 48 persone hanno completato questa guida.
Hi, i wonder if you could help me... I changed my cracked screen (my ipod worked even though the screen was broken) but then when I assembled the ipod ( I did everything you did) it doesn't work, nor does my computer recognize it anymore. Would you happen to know what might be the problem? Have I unintentionally somehow damaged it?
d1k4 - Replica
Thanks for the guide Andrew! I've just replaced my cracked screen and everything works flawlessly.
Cristian Dragos - Replica
Is there any where to send them in and have a professional repair them. I’ve tired some of the things on the site but I think I may have damaged them further? Please advise.
Valerie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 279
Tutti i Tempi: 90,206
