Introduzione
Upgrade your storage with a new hard drive.
Before opening your iPod, ensure that the hold switch is in the locked position.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
Aggiungi Commento
Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Aggiungi Commento
Continue to run the opening tool along the side of the case until all five tabs have been released.
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
Aggiungi Commento
Spedizione gratuita su tutti gli ordini da 79,00 US$ in su.
Sfoglia il Nostro Negozio
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
Aggiungi Commento
Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
Aggiungi Commento
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
  • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
Aggiungi Commento
Peel up the metallic tape attached to the top of the battery.
  • Peel up the metallic tape attached to the top of the battery.
Aggiungi Commento
Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
  • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
Aggiungi Commento
Carefully disconnect the orange ribbon cable from the hard drive.
  • Carefully disconnect the orange ribbon cable from the hard drive.
  • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
  • Lift the hard drive out of the iPod.
Aggiungi Commento
Conclusione
iRobot
Membro da: 24/09/2009
1 Reputazione
745 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 45
Tutti i Tempi: 13,500
