Salta al contenuto principale
iPhone 4S Silent Switch Replacement
Cosa ti serve
  1. iPhone 4S Silent Switch Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
    • Be sure the driver is well-seated when removing Pentalobe screwsโ€”they are easy to strip.
  2. iPhone 4S Silent Switch Replacement: passo 2, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 2, immagine 2 di 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4S Silent Switch Replacement: passo 3, immagine 1 di 1
    • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
    • Remove the rear panel from the iPhone.
  4. iPhone 4S Silent Switch Replacement, Battery: passo 4, immagine 1 di 2 iPhone 4S Silent Switch Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the following screws securing the battery connector to the logic board:
    • One 1.7 mm Phillips screw
    • One 1.5 mm Phillips screw
  5. iPhone 4S Silent Switch Replacement: passo 5, immagine 1 di 3 iPhone 4S Silent Switch Replacement: passo 5, immagine 2 di 3 iPhone 4S Silent Switch Replacement: passo 5, immagine 3 di 3
    • Carefully push the pressure contact away from the battery connector until it slides free from its position.
    • Remove the pressure contact.
  6. iPhone 4S Silent Switch Replacement: passo 6, immagine 1 di 3 iPhone 4S Silent Switch Replacement: passo 6, immagine 2 di 3 iPhone 4S Silent Switch Replacement: passo 6, immagine 3 di 3
    • Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
    • Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
    • The battery connector comes off vertically from the logic board. Do not apply force sideways.
    • Be careful not to pry at the battery connector socket itself, or it may detach from the logic board. There are four very small solder points awaiting this mistake!
  7. iPhone 4S Silent Switch Replacement, Reassembly tip: passo 7, immagine 1 di 2 iPhone 4S Silent Switch Replacement, Reassembly tip: passo 7, immagine 2 di 2
    • During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
    • Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
  8. iPhone 4S Silent Switch Replacement: passo 8, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 8, immagine 2 di 2
    • Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
    • Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
    • If the adhesive is too strong, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a plastic opening tool to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  9. iPhone 4S Silent Switch Replacement: passo 9, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 9, immagine 2 di 2
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • Be careful not to pull the plastic pull tab too hard as it can be ripped off very easily.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the ribbon cable.
    • If your replacement battery came with an uncreased cable, carefully crease the cable into the proper shape before installing the battery into the phone.
    • While installing the replacement battery, temporarily connect the battery connector to the phone to ensure proper alignment. Once the battery is glued in place, disconnect the battery connector.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  10. iPhone 4S Silent Switch Replacement, Dock Connector Cable: passo 10, immagine 1 di 2 iPhone 4S Silent Switch Replacement, Dock Connector Cable: passo 10, immagine 2 di 2
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
  11. iPhone 4S Silent Switch Replacement: passo 11, immagine 1 di 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  12. iPhone 4S Silent Switch Replacement: passo 12, immagine 1 di 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  13. iPhone 4S Silent Switch Replacement: passo 13, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 13, immagine 2 di 2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  14. iPhone 4S Silent Switch Replacement, Rear Camera: passo 14, immagine 1 di 1
    • Be wary of the outer plastic ring located on top of the rear camera's flash assembly. It can be easily displaced if not removed during disassembly.
    • You can use tweezers, a plastic opening tool, or a spudger to remove the outer plastic ring.
  15. iPhone 4S Silent Switch Replacement: passo 15, immagine 1 di 1
    • Remove the following four screws securing the cable cover to the logic board:
    • One 2.7 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 1.3 mm Phillips screw
  16. iPhone 4S Silent Switch Replacement: passo 16, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 16, immagine 2 di 2
    • Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
    • Lift the cable cover from its edge nearest the top and remove it from the iPhone.
  17. iPhone 4S Silent Switch Replacement: passo 17, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 17, immagine 2 di 2
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • There is a small rubber gasket that sits underneath the rear-facing camera. Make sure that it is properly seated before reassembly.
  18. iPhone 4S Silent Switch Replacement, SIM Card: passo 18, immagine 1 di 2 iPhone 4S Silent Switch Replacement, SIM Card: passo 18, immagine 2 di 2
    • Use a SIM eject tool or a paperclip to eject the SIM and its tray.
    • This may require a significant amount of force.
    • Remove the SIM and its tray.
  19. iPhone 4S Silent Switch Replacement, Logic Board: passo 19, immagine 1 di 2 iPhone 4S Silent Switch Replacement, Logic Board: passo 19, immagine 2 di 2
    • Remove the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
  20. iPhone 4S Silent Switch Replacement: passo 20, immagine 1 di 1
    • Remove the 1.5 mm Phillips screw securing the grounding clip to the logic board near the headphone jack.
  21. iPhone 4S Silent Switch Replacement: passo 21, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 21, immagine 2 di 2
    • Use the tip of a spudger to pry the small grounding clip up off the logic board.
    • Carefully grasp the grounding clip and remove it from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the grounding clip (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
  22. iPhone 4S Silent Switch Replacement: passo 22, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Standoff Screwdriver for iPhones
    $5.49
    Compra
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the jobโ€”but use extra caution to ensure it doesn't slip and damage surrounding components.
  23. iPhone 4S Silent Switch Replacement: passo 23, immagine 1 di 1
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna from the logic board.
  24. iPhone 4S Silent Switch Replacement: passo 24, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 24, immagine 2 di 2
    • If present, peel the piece of black tape covering the hidden screw near the power button.
    • Remove the 2.6 mm Phillips screw securing the logic board near the power button.
    • (Use caution when removing this screw and removing the power contact held by it; the contact tab will come loose with the screw)
    • Notice the small rubber bumper under the screen & digitizer cables (which are detached at top above the Q-code). This bumper can fall off of the logic board when removed or get stuck to the cables and fall off later.
  25. iPhone 4S Silent Switch Replacement: passo 25, immagine 1 di 1
    • Remove the following screws securing the logic board to the case:
    • One 2.5 mm Phillips screw near the vibrator motor
    • One 2.4 mm Phillips screw
    • One 3.6 mm standoff along the side of the logic board nearest the battery opening.
    • Use a standoff driver bit and driver handle to remove the single 3.6 mm standoff screw.
  26. iPhone 4S Silent Switch Replacement: passo 26, immagine 1 di 1
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There is a small rubber bumper that sits on the top edge of the logic board where the digitizer and screen cables come through the case. It protects the cables as they bend over the top of the logic board. This can either get stuck to the cables or fall off the logic board when it comes out. Look back over step 22 for more details.
  27. iPhone 4S Silent Switch Replacement: passo 27, immagine 1 di 1
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button. This finger rests on top of the PCB, screwed down, and covered with the adhesive black plastic tape.
  28. iPhone 4S Silent Switch Replacement, Front Facing Camera: passo 28, immagine 1 di 2 iPhone 4S Silent Switch Replacement, Front Facing Camera: passo 28, immagine 2 di 2
    • Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
    • Remove the front facing camera retainer.
  29. iPhone 4S Silent Switch Replacement: passo 29, immagine 1 di 1
    • Remove the front facing camera.
  30. iPhone 4S Silent Switch Replacement, Upper Antenna: passo 30, immagine 1 di 1
    • Remove the 2.4 mm Phillips screw next to the headphone jack.
  31. iPhone 4S Silent Switch Replacement: passo 31, immagine 1 di 2 iPhone 4S Silent Switch Replacement: passo 31, immagine 2 di 2
    • Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
    • Use a pair of tweezers to remove the upper antenna from the iPhone.
    • Before reassembly, be sure to clean the metal-to-metal contact point on the upper antenna (not the mating halves of its connector) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
  32. iPhone 4S Silent Switch Replacement, Headphone Jack Cable Assembly: passo 32, immagine 1 di 3 iPhone 4S Silent Switch Replacement, Headphone Jack Cable Assembly: passo 32, immagine 2 di 3 iPhone 4S Silent Switch Replacement, Headphone Jack Cable Assembly: passo 32, immagine 3 di 3
    • In this step, be careful not to remove the headphone jack without first separating the top microphone from the upper case, as they are connected by a fragile flex cable.
    • Use a plastic opening tool to start to pry the headphone jack out of its recess in the rear case.
    • Then use the opening tool to gently peel the microphone up from the adhesive securing it to the top of the rear case.
    • Remove the headphone jack assembly from the rear case, being careful not to tear the microphone flex cable.
  33. iPhone 4S Silent Switch Replacement: passo 33, immagine 1 di 1
    • Remove the 1.6 mm Phillips screw securing the mute switch bracket to the outer case.
  34. iPhone 4S Silent Switch Replacement: passo 34, immagine 1 di 1
    • Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
  35. iPhone 4S Silent Switch Replacement: passo 35, immagine 1 di 1
    • Use a pair of tweezers to gently pull the silent switch bracket away from the outer case.
  36. iPhone 4S Silent Switch Replacement: passo 36, immagine 1 di 1
    • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
    • Remove the headphone jack cable assembly from the iPhone.
  37. iPhone 4S Silent Switch Replacement, Silent Switch: passo 37, immagine 1 di 2 iPhone 4S Silent Switch Replacement, Silent Switch: passo 37, immagine 2 di 2
    • Use a pair of tweezers to remove the silent switch from the case of the iPhone.
    • During reassembly, the orange bar should be closest to the front of the iPhone when the silent switch is installed.
Conclusione
Altre 64 persone hanno completato questa guida.
4 Commenti
My iPhone 4s when on silent keeps jumping to loud by itself. Fixed it by wedging bit of folded cardboard inbetween battery and the ribbon wire which goes to switch
Noby - Replica
Same problem. Explain briefly. First timer.
alizaheer66 -
Great guide. Easy to follow the step by step instructions with visual guide. But, what would make it slightly better for total beginners like me would be to provide a guide on how to put it back together again. Lol. Also if you could show how to exactly fit the new flex with the silent button as im having trouble keeping it in place/position.
Taz Khan - Replica
Hi. I just made all steps to replace the conexion of the volume up/down that were damaged by water, I fixed it BUT: now the headphone may be making a contact that says to the iPhone that there's a jack inserted, then the speakers doesn't make any sound. All other thing looks fine, including the mic. Only the SIM card died, but it was very used and I will ask for a new one).
Any idea about what happens to the speaker or the headphone conexion?
I'm very tired after this difficult operation then I will back later. Thank you.
Guillermo, from Madrid, Spain.
Guille Velasco - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 52
Tutti i Tempi: 85,365
