Introduzione
Use this guide to open your iPad Mini 3 and replace the display.
We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
  • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
  • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
which temperature must be used for heating? Thx
fbarletta - Replica
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - Replica
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - Replica
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - Replica
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - Replica
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - Replica
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - Replica
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - Replica
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - Replica
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - Replica
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - Replica
Heat the iOpener for thirty seconds.
  • Heat the iOpener for thirty seconds.
  • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
  • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
  • Never touch the iOpener if it appears swollen.
  • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - Replica
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - Replica
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - Replica
I don't own a microwave.
mdanihy - Replica
Its again waterproof when you change iphone 7 battery?
Jon - Replica
I don't have a microwave???
Joe Blow - Replica
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - Replica
can i use just ordinary microwave???
juneseok kwon - Replica
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - Replica
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - Replica
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - Replica
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - Replica
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - Replica
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - Replica
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
  • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
  • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
Will a hair dryer work for heating the glass?
Me berg - Replica
Yes, as does a heat gun.
anonymous 4602 - Replica
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
  • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
  • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
Aggiungi Commento
Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
  • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
  • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
Can you explain how using the iOpener ? That's can be great !
Matthieu Nasri - Replica
The iOpener used is essentially a bag of gel, which you put in the microwave for 30 seconds. You lay this against the screen edges to transfer heat and loosen up the glue.
You could also use a hot-air blower with a re-work station but that's up to you. Mine worked well up to 150°C
Sam Attwood -
what about heating a cloth bag filled with rice in the microwave? Would that work?
SkipR - Replica
That might work! Rice is less likely to get, and stay, hot enough. But it can't hurt to try! Just be sure you're being patient and letting it really warm up before you pry. People have had luck double bagging a washcloth dipped in very hot water, too.
Sam Lionheart -
Carefully place a suction cup halfway up the heated side. Be sure the cup is completely flat on the screen to get a tight seal. While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
  • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
I'm having trouble getting the suction cup to stay connected to the screen to pull it. It just isn't creating a seal no matter how flat I make it. I thought maybe the crack was causing it, so I tried tape. I originally didn't put tape on it because it wasn't losing glass. The tape made it worse of creating a seal. Any advice?
William - Replica
While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad. Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD. Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
  • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
Could I use some guitar picks? If so, what gauge (thickness) of a picks should I get?
SkipR - Replica
I'm not sure what the correct balance of thickness to strength you'd need, maybe try a couple different types. The idea is to be thin and fit into the smallest gap, but if it gets bogged down in adhesive, it needs to be strong enough to push through. Be sure to use heat and be patient!
Sam Lionheart -
Reheat and reapply the iOpener.
  • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  • Let it rest for a few minutes to reheat the left edge of the iPad.
Well if you want to save some time and your screen is shattered just pry up one corner either left or right side at the top and tear the whole screen off going down towards the home button but do not completely remove the screen there is a wire connecting the digitizer to the board inside but tearing off the screen will skip you down to step 29 :-) i seen this in a video and saved me about an hour after the fact because my screen was cracking as i was inserting the blue picks so i ripped the whole screen off and used some adhesive remover to get off all the extra goo leftover
Chris Grayden - Replica
Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go. Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass. Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
  • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
  • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
Aggiungi Commento
Continue moving the opening pick down the side of the display to release the adhesive. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  • Continue moving the opening pick down the side of the display to release the adhesive.
  • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
Aggiungi Commento
Take the first pick you inserted and slide it up toward the top corner of the iPad. If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off. If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Aggiungi Commento
Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
  • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
  • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
Aggiungi Commento
Slide the opening pick around the top left corner of the iPad to separate the adhesive. Slide the opening pick around the top left corner of the iPad to separate the adhesive. Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
Aggiungi Commento
Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera. The third image shows where the front-facing camera and housing are in the iPad. Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
  • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
Aggiungi Commento
Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge. Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge. Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
Aggiungi Commento
Leave the opening pick in the iPad slightly past the front-facing camera. Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive. Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  • Leave the opening pick in the iPad slightly past the front-facing camera.
  • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
  • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Aggiungi Commento
Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner. Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner. Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
Aggiungi Commento
Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
  • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
  • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
Aggiungi Commento
Slide the top right opening pick around the corner to fully release the top edge of the glass. Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  • Slide the top right opening pick around the corner to fully release the top edge of the glass.
  • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
Aggiungi Commento
Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go. Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go. Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
Aggiungi Commento
Continue to slide the pick down the right edge of the iPad, releasing the adhesive. Continue to slide the pick down the right edge of the iPad, releasing the adhesive. Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
  • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
Aggiungi Commento
Leave the opening picks in place and reheat the iOpener.
  • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
  • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
For those who are replacing a severely shattered front panel, be aware that there are two smart cover magnets attached to the interior side of the front panel that you will need later. Keep an eye out for them (see steps 49 and 50 below for pictures of what these tiny magnets look like) so that you don't have to go digging through the debris later.
Jeff G - Replica
Slide the lower left pick to the lower left corner to cut the adhesive on that corner. Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad. There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
  • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
  • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
  • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
    • Antennas
    • Home button cavity
    • Digitizer cable
  • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Aggiungi Commento
Leave the pick from the last step in place to prevent the adhesive from re-sealing. With a new pick, slice gently over the left-hand antenna, stopping before the home button. Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
  • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
  • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
  • Leave the pick in place before moving on.
Aggiungi Commento
Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button. Stop about an inch from the right-hand side to avoid cutting the digitizer cable. Insert the pick slightly deeper and work it back toward the home button.
  • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
  • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
  • Insert the pick slightly deeper and work it back toward the home button.
  • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
Aggiungi Commento
Reheat and reapply the iOpener to the top bezel of the iPad.
  • Reheat and reapply the iOpener to the top bezel of the iPad.
Aggiungi Commento
Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat. At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
  • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
  • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
  • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
Aggiungi Commento
Lift slowly and gently to further detach the adhesive along the lower edge. Lift slowly and gently to further detach the adhesive along the lower edge.
  • Lift slowly and gently to further detach the adhesive along the lower edge.
Aggiungi Commento
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace. Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
  • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
This picture and several others that follow are not for the "LTE" model.
Tim Osborn - Replica
Remember to remove the old black adhesive from the digitizer and iPad frame. Some can be pulled out and some needs a sharp blade to remove. This will give you room to apply your new adhesive strips when reassembling.
The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it. Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel. Return the front-facing camera housing to its recess in the rear case.
  • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
  • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
  • Return the front-facing camera housing to its recess in the rear case.
Aggiungi Commento
Remove the following Phillips #00 screws securing the LCD: Three 3.3 mm screws
  • Remove the following Phillips #00 screws securing the LCD:
    • Three 3.3 mm screws
    • One 4.5 mm screw
  • If there is tape covering any LCD screws, peel it up with tweezers.
This is VERY IMPORTANT please be sure to put the screws EXACTLY how they were when you removed them otherwise your screen will not rotate when you put the new digitizer on. i closed my ipad thinking everything was ok but now the screen does not automatically rotate, but lucky i jailbroke my ipad first and have an activator gesture to rotate for me :-)
stripped the screws at the home button side of the ipad and the precision screw extractor set is too big to work. help?! paramedic064@gmail.com
paramedic064 - Replica
We have some great posts on Answers about getting stripped screws out, you can refer to What are your tips/tricks for removing or extracting stripped screws? for advice, or ask a new one and see if someone can come up with new ideas. We also have a stripped screw removal guide for you to check out. Good luck!
Sam Lionheart -
I found that Phillips #000 work better then the Phillips #00 for this entire product. I'll be recommending a change to the fix kit as well.
William - Replica
This is a tip:
I have a terrible time cleaning the lcd because no matter how hard I try not to touch it, I always get smudges! So take my advice…remove the front film from the new digitizer and place it over the lcd. It is bigger so you can cut it down or just lift it to get to the screws. Now no fingerprints and also less chance for scratches. The front side is easy to clean once it’s installed so need to have that covered while working-the insides are what needs protecting.
mamashannon4u - Replica
Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end. Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
  • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Be very careful not to get the spudger under the shield plate, but between the LCD and the shield. Also, not that on the LTE models, the antennas are at this end and there is a bit of adhesive holding this end of the LCD down.
This bit of adhesive is located beneath the foam, and runs the entire length of the antennas. You must lift the foam and detach the tape before you're able to get the top to come out the chassis
James - Replica
This is not present in this tutorial and is very frustrating. I fix it must look into this
James - Replica
I have seen countless comments about the LCD breaking when trying to remove it from the LCD shield with adhesive. I have found a simple solution. Once the 4 screws have been removed take a piece of fishing line (longer than the iPad) and simply run it beneath the top of the LCD from one side to the other. Once it's in place, gently pull it down applying equal pressure from both sides. The fishing line will break the adhesive in the process, freeing the LCD. It has worked for me every time.
bababooey - Replica
Thanks for the fishing line suggestion. It certainly worked for me (used 6lb test line). With using the fishing line, one is a lot less likely to break the LCD compared to using a spudger.
rgstout -
awesome tip thanks
Pa Du -
The tutorial procedure should be edited once and for all to instruct to detach the adhesive strip from the top of the LCD prior to attempting to lift it. Failure to do so will invariably result in a broken LCD!!!
The simplest way to do that is to first gently remove the foam strip running around the top of the LCD with a pair of tweezers. Only then will the shiny metallic adhesive tape be visible and accessible.
lorenzocangiano - Replica
The LCD is secured by mild adhesive that should be loosened before you flip the LCD up from its shield plate. Insert the spudger between the LCD and LCD shield plate and slide it to the far edge of the iPad. Insert the spudger between the LCD and LCD shield plate and slide it to the far edge of the iPad.
  • The LCD is secured by mild adhesive that should be loosened before you flip the LCD up from its shield plate.
  • Insert the spudger between the LCD and LCD shield plate and slide it to the far edge of the iPad.
Hi. I noticed that the tutorial is for an LTE iPad mini 2. However, these pictures do not show and LTE device. I'm having issues removing the LCD from the iPad due to the antenna. Any suggestions? (How to remove antenna?)
Kevin Rodriguez - Replica
This step needs extra detail on how the LCD adhesive should be loosened. I've now got stress marks on the LCD which show up when solid backgrounds are displayed on screen as the LCD flexed when trying to pry it out.
Cool_Breeze - Replica
bababooey - Replica
Great tip about the fishing wire because you will most certainly crack the LCD just yanking it out. Thank you and hit em with the hein
Curtis Jordan Lenox - Replica
Two wide strips of tape connect the LCD to the speakers. Hold the LCD with one hand, and the rear body of the iPad with the other.
  • Two wide strips of tape connect the LCD to the speakers.
  • Hold the LCD with one hand, and the rear body of the iPad with the other.
  • Do not attempt to fully remove the LCD from the iPad.
  • Gently pull the LCD away from the speakers to separate the tape, being careful not to pull on the digitizer cable.
this was a pain to remove but the two pieces of tape should be separated using your spudger so that you can remove the lcd.
The screen was a tight fit in the recess. Whilst maneouvering it out, it flexed a little. Once reassembled, there are now feint stress marks visible when the screen displays a uniform background. With photos it's not noticeable, but on solid backgrounds, it is very noticeable. :-(
Be careful when pulling the LCD out. Any hints for pulling it out safely should be added to this step.
This step is bad advise. Once you get the LCD unglued top and sides, drop those plastic tools behind it to keep it up and apply heat to the front bottom of the LCD where the tape is applied on either side, use your spudger to push the tape away before you attempt to pull or flip the LCD over. It is very easy to break if you don't get the tape loose enough, so do yourself a favor and free the LCD from the tape before you attempt to maneuver it.
brentschwartz - Replica
bababooey - Replica
As others have said this step is rather problematic and following the tuturial instructions will most definitely lead to damaging the LCD. One problem is that the two adhesive tapes are not indicated in the photo: they are large and black and they are partly covered by long strips of thicker material that looks like padding. To remove them it helps to heat a little with the opener and then one can slowly peel them away by alternating the sharp and flat tips of the spudger.
This must be the most difficult part. I took the advice of using fishing line and it worked a treat. However, due to lack of knowledge - I managed to slice straight through the LCD ribbons (all of them). I figure it was glue so kept going! Please take not that fishing line is only good for the sides, not the top where the LCD is attached! New LCD on order for round 2.
Mike - Replica
Well. I cracked the LCD during this process, so another $100. But, it’s the journey that counts, right? There is adhesive keeping the LCD attached to the aluminum shield. As I was prying the LCD up (I didn't know about the adhesive), I did hear feint cracking. Also it is too tight to try to flip the LCD over as shown. I did heat the bottom strips, but still tried to do it as shown, more cracking. It seems best to heat it and push the adhesive strips back and separate them prior to lifting. As well as the sides of the LCD for lifting!!
William Dailey - Replica
Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end. Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
  • Lay the LCD on the front panel glass to allow access to the display cables.
Aggiungi Commento
Slide the tip of a spudger between the LCD and the adhesive tabs to free the display. Push gently between each of the two adhesive tabs; be careful not to damage any of the nearby cables. Push gently between each of the two adhesive tabs; be careful not to damage any of the nearby cables.
  • Slide the tip of a spudger between the LCD and the adhesive tabs to free the display.
  • Push gently between each of the two adhesive tabs; be careful not to damage any of the nearby cables.
Aggiungi Commento
Remove the seven 1.8 mm Phillips #00 screws from the LCD shield plate.
  • Remove the seven 1.8 mm Phillips #00 screws from the LCD shield plate.
My LCD shield plate had many more screws than this. You have to remove them all.
David Rowthorn - Replica
Use the flat end of a spudger to pry the LCD shield plate up and out of the iPad. Remove the LCD shield plate. Remove the LCD shield plate.
  • Use the flat end of a spudger to pry the LCD shield plate up and out of the iPad.
  • Remove the LCD shield plate.
You can also just slide it back to expose the cable bracket.
Will - Replica
Remove the following Phillips #00 screws from the display cable bracket:
  • Remove the following Phillips #00 screws from the display cable bracket:
    • One 2.8 mm screw
    • Three 1.4 mm screws
Aggiungi Commento
Remove the display cable bracket from the iPad. Remove the display cable bracket from the iPad. Remove the display cable bracket from the iPad.
  • Remove the display cable bracket from the iPad.
Aggiungi Commento
Use the tip of a spudger to lift the home button cable up off of its socket on the logic board. Fold the home button ribbon cable out of the way. Fold the home button ribbon cable out of the way.
  • Use the tip of a spudger to lift the home button cable up off of its socket on the logic board.
  • Fold the home button ribbon cable out of the way.
maybe disconnect the battery before touch the home button cable
ChiangFeng Li - Replica
Use the tip of a spudger to gently lift the battery connector up off its socket on the logic board. Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely. Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
  • Use the tip of a spudger to gently lift the battery connector up off its socket on the logic board.
  • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
Aggiungi Commento
Use the tip of a spudger to lift the LCD connector up off its socket on the logic board. Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
  • Use the tip of a spudger to lift the LCD connector up off its socket on the logic board.
  • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
Aggiungi Commento
Lift and remove the LCD from the iPad Mini 3.
  • Lift and remove the LCD from the iPad Mini 3.
Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Sam Lionheart
Membro da: 18/10/2012
314.321 Reputazione
1.633 Guide realizzate
iFixit Membro di iFixit
Community
117 Membri
5.755 Guide realizzate
I’ve done many iPad Mini 1 and 2 repairs and have had no problems. However with the touch ID home button on the iPad Mini 3 it makes it a bit trickier. I haven’t been able to successfully transfer a touch ID capable home button to the new digitizer, let alone install a new home button and have it work.
Anyone have any tips?
Bill Shannon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 120
Tutti i Tempi: 6,156
