Strumenti necessari in questo Smontaggio
Introduzione
This is the teardown for a Clamcase for iPad 2.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo iPad ClamCase, usa il nostro manuale di assistenza.
You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other. Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
  • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
  • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
  • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
Aggiungi Commento
Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side. Use  the T6 Torx screwdriver to unscrew the remaining 4 screws.
  • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
  • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Turn the keyboard cover over so the bottom is facing up.  Manually remove the thin black covering that is attached to the bottom. Be patient, the thin black covering might be really stuck to the bottom.
  • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
  • Be patient, the thin black covering might be really stuck to the bottom.
Aggiungi Commento
Once the thin black covering is removed, you will see 15 screws.
  • Once the thin black covering is removed, you will see 15 screws.
  • Use the T6 Torx screwdriver to remove the screws.
Aggiungi Commento
Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
Aggiungi Commento
You are done.
  • You are done.
Aggiungi Commento
Izmet Barranco
Membro da: 12/12/2012
213 Reputazione
1 Guida realizzata
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Replica
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 6,168
