Salta al contenuto principale
iPad 4 Wi-Fi Battery Replacement
Cosa ti serve
  1. iPad 4 Wi-Fi Battery Replacement, iOpener Heating: passo 1, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement, iOpener Heating: passo 1, immagine 2 di 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    Chiedi a FixBot
  2. iPad 4 Wi-Fi Battery Replacement: passo 2, immagine 1 di 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    Chiedi a FixBot
  3. iPad 4 Wi-Fi Battery Replacement: passo 3, immagine 1 di 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Chiedi a FixBot
  4. iPad 4 Wi-Fi Battery Replacement, Alternate iOpener heating method: passo 4, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement, Alternate iOpener heating method: passo 4, immagine 2 di 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    Chiedi a FixBot
  5. iPad 4 Wi-Fi Battery Replacement, Front Panel: passo 5, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement, Front Panel: passo 5, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement, Front Panel: passo 5, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Chiedi a FixBot
  6. iPad 4 Wi-Fi Battery Replacement: passo 6, immagine 1 di 1
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
    Chiedi a FixBot
  7. iPad 4 Wi-Fi Battery Replacement: passo 7, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 7, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 7, immagine 3 di 3
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
    Chiedi a FixBot
  8. iPad 4 Wi-Fi Battery Replacement: passo 8, immagine 1 di 1
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
    Chiedi a FixBot
  9. iPad 4 Wi-Fi Battery Replacement: passo 9, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 9, immagine 2 di 2
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
    Chiedi a FixBot
  10. iPad 4 Wi-Fi Battery Replacement: passo 10, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 10, immagine 2 di 2
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
    Chiedi a FixBot
  11. iPad 4 Wi-Fi Battery Replacement: passo 11, immagine 1 di 1
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
    Chiedi a FixBot
  12. iPad 4 Wi-Fi Battery Replacement: passo 12, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 12, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 12, immagine 3 di 3
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
    Chiedi a FixBot
  13. iPad 4 Wi-Fi Battery Replacement: passo 13, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 13, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 13, immagine 3 di 3
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    Chiedi a FixBot
  14. iPad 4 Wi-Fi Battery Replacement: passo 14, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 14, immagine 2 di 2
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
    Chiedi a FixBot
  15. iPad 4 Wi-Fi Battery Replacement: passo 15, immagine 1 di 1
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
    Chiedi a FixBot
  16. iPad 4 Wi-Fi Battery Replacement: passo 16, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 16, immagine 2 di 2
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
    Chiedi a FixBot
  17. iPad 4 Wi-Fi Battery Replacement: passo 17, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 17, immagine 2 di 2
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
    Chiedi a FixBot
  18. iPad 4 Wi-Fi Battery Replacement: passo 18, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 18, immagine 2 di 2
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
    Chiedi a FixBot
  19. iPad 4 Wi-Fi Battery Replacement: passo 19, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 19, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 19, immagine 3 di 3
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
    Chiedi a FixBot
  20. iPad 4 Wi-Fi Battery Replacement: passo 20, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 20, immagine 2 di 2
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
    Chiedi a FixBot
  21. iPad 4 Wi-Fi Battery Replacement: passo 21, immagine 1 di 1
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
    Chiedi a FixBot
  22. iPad 4 Wi-Fi Battery Replacement: passo 22, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 22, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 22, immagine 3 di 3
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
    Chiedi a FixBot
  23. iPad 4 Wi-Fi Battery Replacement: passo 23, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 23, immagine 2 di 2
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
    Chiedi a FixBot
  24. iPad 4 Wi-Fi Battery Replacement: passo 24, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 24, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 24, immagine 3 di 3
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
    Chiedi a FixBot
  25. iPad 4 Wi-Fi Battery Replacement: passo 25, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 25, immagine 2 di 2
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
    Chiedi a FixBot
  26. iPad 4 Wi-Fi Battery Replacement: passo 26, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 26, immagine 2 di 2
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
    Chiedi a FixBot
  27. iPad 4 Wi-Fi Battery Replacement: passo 27, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 27, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
    Chiedi a FixBot
  28. iPad 4 Wi-Fi Battery Replacement, Front Panel Assembly: passo 28, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement, Front Panel Assembly: passo 28, immagine 2 di 2
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
    • The bottom left screw is obscured by the home button ribbon cable connector. Carefully move the home button ribbon cable aside to remove the bottom left screw.
    Chiedi a FixBot
  29. iPad 4 Wi-Fi Battery Replacement: passo 29, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 29, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 29, immagine 3 di 3
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front glass panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
    Chiedi a FixBot
  30. iPad 4 Wi-Fi Battery Replacement, LCD: passo 30, immagine 1 di 1
    • Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
    Chiedi a FixBot
  31. iPad 4 Wi-Fi Battery Replacement: passo 31, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 31, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 31, immagine 3 di 3
    • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
    Chiedi a FixBot
  32. iPad 4 Wi-Fi Battery Replacement: passo 32, immagine 1 di 1
    • Without touching the front of the LCD, lift the LCD off the front panel.
    Chiedi a FixBot
  33. iPad 4 Wi-Fi Battery Replacement, Front Panel Assembly: passo 33, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement, Front Panel Assembly: passo 33, immagine 2 di 2
    • If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable.
    Chiedi a FixBot
  34. iPad 4 Wi-Fi Battery Replacement: passo 34, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 34, immagine 2 di 2
    • Flip up the retaining flap on the home button ribbon cable ZIF connector.
    Chiedi a FixBot
  35. iPad 4 Wi-Fi Battery Replacement: passo 35, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 35, immagine 2 di 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board.
    Chiedi a FixBot
  36. iPad 4 Wi-Fi Battery Replacement: passo 36, immagine 1 di 1
    • De-route the home button ribbon cable from its recess in the rear case.
    Chiedi a FixBot
  37. iPad 4 Wi-Fi Battery Replacement: passo 37, immagine 1 di 1
    • Use a pair of tweezers to peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
    Chiedi a FixBot
  38. iPad 4 Wi-Fi Battery Replacement: passo 38, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 38, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 38, immagine 3 di 3
    • Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
    Chiedi a FixBot
  39. iPad 4 Wi-Fi Battery Replacement: passo 39, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 39, immagine 2 di 2
    • Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable.
    • Pull the digitizer ribbon cable straight out of its sockets on the logic board.
    Chiedi a FixBot
  40. iPad 4 Wi-Fi Battery Replacement: passo 40, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 40, immagine 2 di 2
    • Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
    Chiedi a FixBot
  41. iPad 4 Wi-Fi Battery Replacement: passo 41, immagine 1 di 1
    • Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
    • Remove the front panel from the iPad.
    Chiedi a FixBot
  42. iPad 4 Wi-Fi Battery Replacement, Headphone Jack Cable: passo 42, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement, Headphone Jack Cable: passo 42, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement, Headphone Jack Cable: passo 42, immagine 3 di 3
    • Use tweezers to peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
    • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
    Chiedi a FixBot
  43. iPad 4 Wi-Fi Battery Replacement: passo 43, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 43, immagine 2 di 2
    • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
    • Pull the headphone jack assembly cable straight out of its socket on the logic board.
    Chiedi a FixBot
  44. iPad 4 Wi-Fi Battery Replacement, Logic Board Connectors: passo 44, immagine 1 di 1
    • Disconnect the following connectors from their respective sockets on the logic board:
    • Wi-Fi antenna cable
    • Speaker connector cable.
    • Dock/Lightning connector cable.
    • There may be a piece of black tape covering this connector. Remove it with tweezers.
    • Make sure to pry underneath the connector and not the socket itself. Prying on the socket itself may cause severe damage.
    Chiedi a FixBot
  45. iPad 4 Wi-Fi Battery Replacement, Logic Board: passo 45, immagine 1 di 1
    • Remove the following four screws securing the logic board to the rear aluminum panel.
    • Three 2.1mm Phillips #00
    • One 2.5mm Phillips #00
    Chiedi a FixBot
  46. iPad 4 Wi-Fi Battery Replacement: passo 46, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 46, immagine 2 di 2
    • Holding the logic board by the side opposite the Lightning connector, carefully pull the logic board away from the iPad.
    Chiedi a FixBot
  47. iPad 4 Wi-Fi Battery Replacement, Battery: passo 47, immagine 1 di 1
    • The battery is very firmly glued to the aluminum frame using copious amounts of strong adhesive.
    • In the following steps, you will be removing the adhesive from underneath the battery 2 inches at a time. This will prevent too much stress being put on the battery.
    • Be very careful to not puncture or damage the battery as you remove it from the iPad. Batteries contain toxic chemicals that can be harmful if ingested or inhaled.
    Chiedi a FixBot
  48. iPad 4 Wi-Fi Battery Replacement: passo 48, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 48, immagine 2 di 2
    • Insert the flat end of a metal spudger underneath the battery near the bottom of the iPad.
    • Slide the metal spudger approximately 1.5" underneath the battery, releasing the adhesive.
    • The adhesive is very strong. Loosening the adhesive requires considerable force. Work slowly and carefully, making sure that the metal spudger does not slip.
    Chiedi a FixBot
  49. iPad 4 Wi-Fi Battery Replacement: passo 49, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 49, immagine 2 di 2
    • In the same manner as described above, slide the spudger ~2" underneath the other adhesive strips.
    Chiedi a FixBot
  50. iPad 4 Wi-Fi Battery Replacement: passo 50, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 50, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 50, immagine 3 di 3
    • Carefully slide the metal spudger underneath the battery connector, releasing the adhesive securing it in place.
    Chiedi a FixBot
  51. iPad 4 Wi-Fi Battery Replacement: passo 51, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 51, immagine 2 di 2
    • Continue releasing the adhesive near the top of the battery.
    Chiedi a FixBot
  52. iPad 4 Wi-Fi Battery Replacement: passo 52, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 52, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 52, immagine 3 di 3
    • Starting where the last pass left off, insert the metal spudger another two inches underneath the battery.
    • As you push the spudger further underneath the battery, keep it as flat against the rear case as possible to avoid bending the battery.
    • Repeat this process for the remaining adhesive strips.
    Chiedi a FixBot
  53. iPad 4 Wi-Fi Battery Replacement: passo 53, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 53, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 53, immagine 3 di 3
    • In the same manner as previously described, continue loosening the adhesive on all the strips to a depth of ~4".
    Chiedi a FixBot
  54. iPad 4 Wi-Fi Battery Replacement: passo 54, immagine 1 di 3 iPad 4 Wi-Fi Battery Replacement: passo 54, immagine 2 di 3 iPad 4 Wi-Fi Battery Replacement: passo 54, immagine 3 di 3
    • For the last pass, push the metal spudger all the way to the right edge of the iPad.
    • Continue to do this for all of the adhesive strips.
    Chiedi a FixBot
  55. iPad 4 Wi-Fi Battery Replacement: passo 55, immagine 1 di 2 iPad 4 Wi-Fi Battery Replacement: passo 55, immagine 2 di 2
    • Make sure that all the adhesive glue has been loosed from the battery.
    • Gently lift the left side of the battery up, rotating it toward the right side of the iPad.
    • Use the metal spudger to loosen any adhesive that may still be holding the battery in place
    • Remove the battery from the iPad.
    Chiedi a FixBot
Conclusione
To reassemble your device, follow these directions in reverse and use our iPad 4 Wi-Fi Front Panel Adhesive strips guide to reattach the front panel.
Altre 60 persone hanno completato questa guida.
10Commenti sulla guida
I have just done this replacement, but have some problems now with the charging.
The iPad indicates charging (lightning symbol next to battery icon), but the charge does not "fill up", instead it resides at 0 percent.
When i disconnect the charger after a few hours, it shows 100%, but only lasts a short time before it plummets to 0% again.
Is there something that needs to be done in the settings etc after replacing the battery? Do i need to reset the iPad, or "tell it" that it has a new battery..?
oyvindrosmer - Rispondi Condividi
Could Be a Charging IC Usually the second culprit of a dying battery.
stephenthormodson - Rispondi Condividi
I know this comment is like 8 years old at this point, but did you make sure that you put the screw in for the battery. It's the orange one in step 45. I had a similar issue with an iPad 9th gen
Konner Koroski - Rispondi Condividi
Thanks for a very precise tutorial! Just completed it and all seems perfect.
Lara Snuffer - Rispondi Condividi
I experienced major confusion during reassembly when attempting to insert the ribbon cable into the ZIF connector slot. An illustration of this would have saved some heart-ache. Otherwise an excellent guide!
Stephen Svoboda - Rispondi Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 313
Tutti i Tempi: 74,347
