Introduzione
Use this guide to replace adhesive strips and re-seal your iPad 4 after a repair.
Only for use with EXISTING front panel assemblies.
Remove the two 2.1 mm Phillips #00 Phillips screws securing the home button control board to the home button mounting bracket.
  • Remove the two 2.1 mm Phillips #00 Phillips screws securing the home button control board to the home button mounting bracket.
Aggiungi Commento
Wedge the flat edge of a plastic opening tool in between the right end of the home button control board and the home button mounting bracket. Depress the plastic opening tool downwards to pry the adhesive securing the home button control board from the home button mounting bracket.
  • Wedge the flat edge of a plastic opening tool in between the right end of the home button control board and the home button mounting bracket.
  • Depress the plastic opening tool downwards to pry the adhesive securing the home button control board from the home button mounting bracket.
  • Repeat the procedure to release the adhesive underneath the left end of the home button control board.
Aggiungi Commento
Lift and remove the home button control board up off the home button mounting bracket.
  • Lift and remove the home button control board up off the home button mounting bracket.
Aggiungi Commento
Use the flat edge of a spudger to scrape the old adhesive off the bottom right corner of the front panel assembly. If necessary, gently peel the old adhesive with a pair of tweezers.
  • Use the flat edge of a spudger to scrape the old adhesive off the bottom right corner of the front panel assembly.
  • If necessary, gently peel the old adhesive with a pair of tweezers.
Aggiungi Commento
Gently place the home button control board on top of the home button mounting bracket. Make sure the home button control board is lined up with the bottom of the home button mounting bracket.
  • Gently place the home button control board on top of the home button mounting bracket.
  • Make sure the home button control board is lined up with the bottom of the home button mounting bracket.
Aggiungi Commento
Insert the two 2.1 mm Phillips #00 Phillips screws back into the home button control board to secure it against the home button mounting bracket.
  • Insert the two 2.1 mm Phillips #00 Phillips screws back into the home button control board to secure it against the home button mounting bracket.
Aggiungi Commento
In the following steps, you will be placing the remaining pieces of adhesive on the front panel. Do not peel the clear backing off the strips just yet. Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
  • In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
  • Do not peel the clear backing off the strips just yet.
  • Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
  • Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Aggiungi Commento
Place the elongated C shaped adhesive strip on the right side of the front panel. Place the elongated C shaped adhesive strip on the right side of the front panel.
  • Place the elongated C shaped adhesive strip on the right side of the front panel.
Aggiungi Commento
It is recommened to lift the home button ribbon cable aside while placing the next adhesive strip. Place the straight, medium length adhesive strip on the bottom right side of the front panel, underneath the home button ribbon cable.
  • It is recommened to lift the home button ribbon cable aside while placing the next adhesive strip.
  • Place the straight, medium length adhesive strip on the bottom right side of the front panel, underneath the home button ribbon cable.
Aggiungi Commento
Place the tabbed rectangular adhesive strip on the bottom right side of the front panel. Place the tabbed rectangular adhesive strip on the bottom right side of the front panel.
  • Place the tabbed rectangular adhesive strip on the bottom right side of the front panel.
Aggiungi Commento
Place the long L-shaped adhesive strip on the bottom left corner of the front panel. Place the long L-shaped adhesive strip on the bottom left corner of the front panel.
  • Place the long L-shaped adhesive strip on the bottom left corner of the front panel.
Aggiungi Commento
Place the short rectangular shaped adhesive strip on the top left side of the front panel. Place the short rectangular shaped adhesive strip on the top left side of the front panel.
  • Place the short rectangular shaped adhesive strip on the top left side of the front panel.
Aggiungi Commento
Place the last, short L-shaped adhesive strip on the top left corner of the front panel. Place the last, short L-shaped adhesive strip on the top left corner of the front panel.
  • Place the last, short L-shaped adhesive strip on the top left corner of the front panel.
Aggiungi Commento
Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable. Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
  • Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
  • Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Aggiungi Commento
Use a dry microfiber cloth to clean the LCD and inside of the front panel glass. You may want to use canned air or an air compressor to blow away and dust.
  • Use a dry microfiber cloth to clean the LCD and inside of the front panel glass. You may want to use canned air or an air compressor to blow away and dust.
  • Use a pair of tweezers to peel the clear backing up off each adhesive strip.
  • Close the front panel down onto the iPad, careful to place it within the plastic bezel, and careful not to get any dirt or fingerprints between the glass and LCD.
  • To ensure a good seal, place the iPad face down on a padded envelope or cloth and pile a couple of books above it to weigh the screen down. Leave it like this for a few hours before using.
Just anted to remind everyone to connect all your cables BEFORE sticking the screen down!!
Eric Viitala - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Andrew Optimus Goldberg
Membro da: 17/10/2009
376.403 Reputazione
1.296 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
6.004 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,968
