Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Introduzione
Replace or upgrade the CPU. Don't forget to apply a new layer of thermal compound before reassembling your iMac.
Follow our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
  • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
  • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
Would a heat gun make this step easier? Or damage the iMac?
Clark Green - Replica
A heat gun wouldn’t help you here as you still need to cut though the adhesive. You also risk damaging the display with the excessive heat.
Dan -
Removing the original adhesive is easier than removing newly applied adhesive (e.g., if you have to reopen iMac).  If you should happen to need to reopen the iMac, please use extreme caution and highly consider my suggestions below.
When using the pizza cutter tool, do the first few steps in reverse starting with step 8.  Starting on the left side is better since this is where the adhesive is narrowest.  The right side has two antennas and the top right has one, see the pictures for step 18-21, they are the brass colored metal rectangles near the edges.  The adhesive on these pieces are wider and therefore have more holding power.  The thickness of the pizza cutter tool is enough to crack the glass.
Walter Hayden - Replica
Continuing from my previous comment.  To remove the adhesive on the right side you’ll need to create a very slight gap to give the pizza cutter some more room.  Do this by cutting the adhesive on the left side up and around to the camera.  Before attempting to cut the right side. Carefully slide the plastic cards (I purchased two sets) to ensure the adhesive on the left top and side is completely free.  Now slowly move towards the right side.  After every inch or two of removing new adhesive, slide the card over to create this slight gap.  Be careful to not move the card too close to where the adhesive has not been cut.  You want to create a very slight gap without creating too much pressure.  Use extra caution with approaching the areas where the antenna are since the adhesive is stronger here and will need some additional cutting.  Follow this approach all the way around the right side.  Be careful to not create too much pressure at any one time.  Good Luck!.
I would highly, highly, highly recommend AGAINST doing this at home. I followed these instructions to a T, and still somehow managed to have the screen not be able to turn on after the hard drive replacement. Then, once you’ve opened your Mac yourself, Apple will refuse to fix anything on the computer, and even other third party, Apple-authorized repair facility will refuse to repair it for you, and you will have to locate a non-authorized Apple repair facility. There, I am having to pay ~$600 to fix things that got screwed up, even though I followed the instructions here to a T, step by step, and did everything slowly and methodically.
Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility, if you mess things up here now.
Luke Gibson - Replica
I performed this on a Late 2015 iMac and there weren’t any significant differences to these steps, but I did find the repair to be nerve-wracking. My model cost nearly $3,000 and about 10 steps into this guide (which I did fully read ahead of time) I was thinking, “what have I got myself into?” But I didn’t rush and happily I’m typing this on my repaired iMac! I found a video from OWC that was more useful than the photos in this guide for certain steps: https://vimeo.com/139364064
Anthony Zimmerman - Replica
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
I found the 'pizza cutter' surprisingly smooth at cutting through four-year-old adhesive.
Gerry - Replica
Continue wheeling the tool up around the top left corner. Continue wheeling the tool up around the top left corner. Continue wheeling the tool up around the top left corner.
  • Continue wheeling the tool up around the top left corner.
Aggiungi Commento
Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
  • Cut the adhesive along the top left of the display.
The pizza cutter will sink in all the way to the tool handle when the adhesive is full cut, but don’t feel you have to do this in one motion. Some parts cut easier and some require a lot (like 20x) of gentle back and forth.
Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  • Continue along the top of the display.
  • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
Aggiungi Commento
Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
  • Push the tool around the top right corner of the display.
Aggiungi Commento
Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
  • Wheel the tool down along the right side of the display.
Aggiungi Commento
Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  • Finish pushing the opening tool to the bottom of the right side of the display.
  • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
Aggiungi Commento
While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
  • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
  • Set the iMac face-up on a table.
  • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
I actually DESTROYED my display (black vertical strips) by pushing the card in a bit TOO DEEP. So it is REALLY important to insert the card only a bit (1-2mm) more than the cutter wheel, in particular at the top side, where many flat cables connect the panel with the PCB. These can be damaged very easily!
Peter Fischer - Replica
Same thing with me…. Pushed cards to far…. new panel needed…€600…..
i think ifixit needs to place a bigger caveat, as I have missed it the first time
Edgar Broekema - Replica
i successfully upgraded two imacs. one opened with ifixit pizza knife and another with a regular paper knife. however, when i had to open the first one once again i broke its screen glass. it seems ifixit adhesive strips are too strong. next time i’ll try to use heater to weaken glue tension.
Eugene Kharkov - Replica
Gently twist the plastic card to open the space between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4" (6mm).
  • Gently twist the plastic card to open the space between the display and frame.
  • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4" (6mm).
My children tend to collect cards like this from hotels, Disneyland, old IDs, iTunes cards, gift cards etc. They came in handy for this step. After wedging in the first card into the left corner, I wedged the left corner, then added cards along the bottom edge. Finally I continued to push in additional cards to existing cards and found that this created a smooth even pressure along the display top. At 2-3 card-thickness the last of the adhesive let go, gentle as a baby.
Be sure to stop cutting before the iSight camera in this step, or you may damage it. Slide the card toward the center of the display, to cut any remaining adhesive. Slide the card toward the center of the display, to cut any remaining adhesive.
  • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
  • Slide the card toward the center of the display, to cut any remaining adhesive.
Aggiungi Commento
Put the card into the corner again and let it stay there to keep the adhesive from resettling. Put the card into the corner again and let it stay there to keep the adhesive from resettling.
  • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Aggiungi Commento
Insert a second card into the gap between the display and frame in the top left corner. Insert a second card into the gap between the display and frame in the top left corner. Insert a second card into the gap between the display and frame in the top left corner.
  • Insert a second card into the gap between the display and frame in the top left corner.
Aggiungi Commento
Gently twist the card, slightly increasing the space between the display and frame. As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
  • Gently twist the card, slightly increasing the space between the display and frame.
  • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
Aggiungi Commento
Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
  • Slide the plastic card toward the center, again stopping just before the iSight camera.
Aggiungi Commento
Insert the card back into the top left corner. Insert the card back into the top left corner.
  • Insert the card back into the top left corner.
Aggiungi Commento
Only lift the display a few inches—it is still attached to the iMac by data and power cables. With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
  • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
  • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
  • Begin to lift the top of the display up from the frame.
Aggiungi Commento
While holding the display up with one hand, use the other to unplug the display power cable. Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
  • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
Mark all cable connectors with a spot of white correction fluid before removal. This will remove the risk, when reinserting them later, of getting them the wrong way round. Yes - I know they will only plug in one way round, but it does make life easier if you are not in perfect lighting!
Alastair Lack - Replica
At this step, if you mess up anything with these 2 cables, especially when plugging them back in, even if you think you’re following the instructions here to a T, then you’re screwed.
The display cable, the wider one, has a lock on it , usually a plastic tape lift tab to release it, once thats flipped it should come out fairly easily, if your experiencing resistance and the cable isn’t coming out then check for this lock/latch, the power cable just pulls out, just don’t rush it everything should go fine, fairly easy to do with the end result a working iMac
Ed tabickman - Replica
Flip up the metal retaining bracket on the display data cable. Disconnect the display data cable. This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
  • Flip up the metal retaining bracket on the display data cable.
  • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
I replaced HDD to SSD and assembled parts again. When I boot up the iMac, I found black lines on display (looks partly not broken).
I searched Internet, and some says graphic card problem, but I didn't touch anything but cable to lift up.
Could the damaged display data cable cause this situation? I hope I could fix this by just replacing the cables..
chansung park - Replica
Sorry, Black lines is a damaged display assembly ;-{ In the process of removing it you either pushed the tool into deep or you torqued the glass severing the tiny wire traces.
Dan -
Same trouble here, is it cable trouble or connector trouble?
redfoxydarrest - Replica
Sorry damaged display
Dan -
I think whenever words like "...is a delicate connection that can be broken. Be sure to pull the [cable in a certain direction] ANYTIME.... It is worth either a closeup or 2, maybe one with annotations or insertion directions and maybe a motion direction arrow with the something like and 'X' char or a circle division slash over the wrong one.
john - Replica
I agree! +1
Jim Reitz -
[|There are 2 cables to disconnect on my Mac (?). Also, I don’t see a metal retaining bracket. I can take a picture, but cannot attach. I got the glass loose with no problem, but am worried about damaging the cables]
Jim Kelly - Replica
Hi Jim! You can go to our Answers Forum to post some better images of your situation!
Sam Lionheart -
Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Lift the display up to a near-vertical position.
  • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
Thank you Stef, that's what i will do next time, i cracked the lower part of the screen went opening very slowly, that's probably why those "tabs are for !!
dforgues - Replica
Thanks Stef, this has saved me! Simple yet very effective.
David Zemsky - Replica
Yep, I cracked the lower corner of the display as well. I failed to work the adhesive enough to loosen it sufficiently. Be careful, I just had to buy my customer another screen!
Peter Haigh - Replica
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
  • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
Would have been helpful to box the same red area when using the plastic card to separate the glue. Since the red blocked picture is inverted, if someone doesn't pay close attention it may not be obvious that the area of concern is at the right top of the graphic pictures in which the plastic card use is being demonstrated..
Wizbang FL - Replica
you don't need to cut the bottom part as the bottom tape is stuck on each side and you can easily pull it out
Thomas Webb - Replica
What is the twisted wire taped to the back of the display that can bee seen in the upper right of the first two pictures? I have an 27” iMac without a screen an my replacement does not have this wire. I think it is a temperature sensor but do not know where it connects to.
Eric - Replica
[|I opened up my iMac and there’s no HDD or SSD in that spot. its just empty.]
John Warmann - Replica
Please update the picture to include the RED BOXED IN AREA that you refer to on all three pictures in this step. I have had a few zaps from these supplies and it is not pleasant.
Charlie Nancarrow - Replica
Be very careful handling the display—it's big, heavy, and made of glass. Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
Aggiungi Commento
  • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
Aggiungi Commento
Remove two 10.0 mm T10 screws.
  • Remove two 10.0 mm T10 screws.
If you just want access to the HD, there is no need to remove any speaker wires - it slides over enough to access the HD screws.
johann beda - Replica
Unplug the left speaker cable from its socket on the logic board. Be sure to pull straight up out of the socket. De-route the cable from the gap between the hard drive and logic board. If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
  • Unplug the left speaker cable from its socket on the logic board. Be sure to pull straight up out of the socket.
  • De-route the cable from the gap between the hard drive and logic board.
  • If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
I didn’t unplug and de-route this cable. Later, Step 29, has you remove the left speaker. This isn’t necessary. If you can just move the speaker over to expose the hard drive mounting screws, so if you’re not going to remove the speaker, you don’t need to unplug it.
Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock. Use a spudger to disconnect the power button connector from its socket on the logic board. Use a spudger to disconnect the power button connector from its socket on the logic board.
  • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
  • Use a spudger to disconnect the power button connector from its socket on the logic board.
Can someone explain what are the solder joint? Or tell me what it looks it?
brianyu - Replica
The silver spots on the circuit boards. You may not want to tackle this alone. If you touch these areas, you can possible get a shock -- harming you and your computer.
Robert -
there is no need to disconnect the speaker, just unscrew it and move aside slightly to reach the HDD screws (about 5mm) - if you want to replace just the main HDD
Take note of exactly what direction this tiny little wire was.
Joseph Ashe - Replica
Lift the left speaker straight up, until the power button cable is exposed (about 0.5"). Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
  • Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
Aggiungi Commento
Gently de-route the power button cable from its groove in the left speaker. Gently de-route the power button cable from its groove in the left speaker. Gently de-route the power button cable from its groove in the left speaker.
  • Gently de-route the power button cable from its groove in the left speaker.
Aggiungi Commento
Lift the left speaker straight up and remove it from the iMac. If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker. Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
  • Lift the left speaker straight up and remove it from the iMac.
  • If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker.
    • Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
I found it wasn't necessary to remove the speaker from the left side to remove the hard drive. You can remove the screws, and then slide it over to the left — giving more than enough room to access the hard drive.
Robert - Replica
me too. don't need to remove it if you only want to change the hd
Alber Einsten -
Agreed, wast of time to fully remove the speaker.
Matthew Gonzalez -
Pull straight up on the SATA data/power cable to disconnect it from the drive. Pull straight up on the SATA data/power cable to disconnect it from the drive.
  • Pull straight up on the SATA data/power cable to disconnect it from the drive.
Aggiungi Commento
Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
  • Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
If you have the iMac sitting upright, there is a potential risk of dropping the screws into the iMac casing. Be cautious or lay it down flat.
Robert - Replica
Been there done that. Had to flip it and shake the heck out of it to get that srew to fall out!
webmail54 - Replica
Grab the hard drive and left hard drive bracket together. Tilt the left side up away from the rear case, and slide the assembly to the left. Remove the hard drive and left hard drive bracket from the iMac.
  • Grab the hard drive and left hard drive bracket together.
  • Tilt the left side up away from the rear case, and slide the assembly to the left.
  • Remove the hard drive and left hard drive bracket from the iMac.
Two notes here:  If you are using OWC’s Thermal Sensor HDD Upgrade Cable, be sure to tuck the cable under the hard drive slightly.  You cannot allow the connector to sit near the top edge since this will not allow the monitor to sit flush with the chassis when it is reattached.  Additionally, the SATA connector does not seem to fit together as snuggly as when it was connect to the HDD, so tape or a plastic cable tie to keep the connection tight may be good insurance to prevent it from coming loose.
If you are planning on dual booting with Windows 10, the Windows 10 installed failed when the SSD and HDD were both connected at the same time.  I had to disconnect the HDD until Windows 10 was installed.  Note: I did a fresh install on a new SSD not configured as a fusion drive.  If you are planning on doing this as well, use packing tape (or something similar) to hold the monitor in place until after installing the OSs.  Then reconnect the HDD and apply the adhesive to the monitor for a permanent seal.  Good Luck!
Hi Walter, i’m looking to replace the broken fusion drive with a SSD, do i have to get the OWC’s Thermal Sensor HDD Upgrade Cable?
Gregorio Alvarado Sahli -
Full removal of the speaker is unnecessary - just very carefully unplug the two-conductor power button cable, which is routed through the groove along the edge of the speaker enclosure. Next, unfasten the two large torx screws holding the speaker enclosure to the chassis. Now you can easily scoot the speaker away from the drive mount - move it over just enough to reach the drive mount’s 2 torx fasteners beneath the edge of the speaker (a CM or two). There’s now enough room to easily remove and replace the drive assembly .
clinton - Replica
Remove the left hard drive bracket. Remove the left hard drive bracket.
  • Remove the left hard drive bracket.
This step is unnecessary. Just leave the bracket in place and set the assembly aside.
When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Disconnect the power supply control cable from the power supply.
  • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  • Disconnect the power supply control cable from the power supply.
I found this cable very difficult to disconnect, be very careful because the cable is between a black tape and it's stuck very hard to the logic board and the cable is very short and you don't have space to move and separate it from the connection! Be patient and take the time you need
MrSchaeffer - Replica
I found than putting the flat end of the spudger at the center of the cable, and tilting it got the cable out without an issue.
jimboom006 - Replica
I was able to use the flat end of the spudger on the sides. You can see a tiny little clip on each side. Be very gentle!
Remove the following four screws securing the power supply to the rear case:
  • Remove the following four screws securing the power supply to the rear case:
    • Two 23.7 mm T10 screws.
    • Two 7.3 mm T10 screws.
In the iMac I just bought (2016), these were not T10. I believe they are T9. Can anyone confirm?
Morgan Crossley - Replica
Regarding the screws on the power supply board (step 35), I can confirm these are not T10 screws as shown in the guide. In my Late 2015 Retina 5k model, the screws are T8. Morgan mentioned T9 and depending on your T9 driver, it may just barely fit but can easily slip and strip the screw. A T8 driver goes deeper in and holds the screw properly.
smudge -
My late 2015 model has these as T8 screws.
Do not attempt to remove the power supply from the case; it is still attached to the logic board by two cables. Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board. Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board.
  • Do not attempt to remove the power supply from the case; it is still attached to the logic board by two cables.
  • Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board.
Aggiungi Commento
Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board. Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board.
  • Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board.
Remember to push in the disconnect tab on the large connector. Carefully insert your finger and push on the tab before you pull on the connector.
Manuel Collazo - Replica
Thank you Manuel, this was a tricky one.
Yes, I pulled the whole socket out because I didn’t know about the tab. Fortunately I was able to place it back in. Not sure if it was glued or how it was anchored but it seems to have a solid connection and I can’t easily pull it out by hand. Once I plug the power cable back in should be ok.
P. Hisada - Replica
This connector was very difficult for me to remove (even after pushing the disconnect tab). Eventually I had to use a pair of needle nose pliers to wiggle it back and forth out of the socket. A lot of the cables on the my late 2015 model were very tight and a struggle to get out.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Flip the top of the power supply towards you, like opening a mailbox, to reveal the AC inlet cable connector. Disconnect the AC inlet cable connector.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  • Flip the top of the power supply towards you, like opening a mailbox, to reveal the AC inlet cable connector.
  • Disconnect the AC inlet cable connector.
To reassemble, do the same in reverse but keep power supply board more upright than slanted down when re-inserting it in to the lower right corner. The lower right screw post has an protrusion under/behind it and the Power Supply's small 2 wire plug must fit between the front of your Mac and the obstruction. Then it just slides right in and then screw it down.
Dan H - Replica
Aggiungi Commento
Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board. Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
  • Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
Aggiungi Commento
Use a spudger to loosen the right speaker cable's connector from its socket on the logic board. Pull the connector to the right to remove it from its socket. Pull the connector to the right to remove it from its socket.
  • Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
  • Pull the connector to the right to remove it from its socket.
Aggiungi Commento
Lift the speaker straight up and remove it from the iMac. Lift the speaker straight up and remove it from the iMac. Lift the speaker straight up and remove it from the iMac.
  • Lift the speaker straight up and remove it from the iMac.
Aggiungi Commento
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
  • Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Aggiungi Commento
Peel the black tape connecting the fan to the exhaust duct back slightly. Leave the tape in place on the exhaust duct, you only need to expose the joint to free the fan.
  • Peel the black tape connecting the fan to the exhaust duct back slightly.
  • Leave the tape in place on the exhaust duct, you only need to expose the joint to free the fan.
Aggiungi Commento
Remove three 12.4 mm T10 screws securing the fan to the rear case.
  • Remove three 12.4 mm T10 screws securing the fan to the rear case.
Aggiungi Commento
Remove the fan from the iMac. Remove the fan from the iMac.
  • Remove the fan from the iMac.
Use a piece of tape around the antenna cables to keep them in the same order, makes reassembly a little easier.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card. Note the original positions for each connector when reconnecting the cables. From left to right on the card, the antennas are connected in the following order: Leftmost
  • Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
  • Note the original positions for each connector when reconnecting the cables. From left to right on the card, the antennas are connected in the following order:
    • Leftmost
    • Top
    • Upper right
    • Lower right
My iMac has a slightly different assembly. There are 2 - T5 torx screws holding little clamps for each cable (2 clamps per screw). Certainly more secure but another size screw to deal with…
Greg Freeman - Replica
My iMac also same with Greg mentioned. need to T5 torx driver. A1419. Late 2015, Korean Version.
Joseph Yang - Replica
This is a delicate connection that can be easily broken. Flip up the metal retaining bracket on the iSight camera cable. Pull the camera cable connector straight out of its socket, toward the top of the iMac.
  • This is a delicate connection that can be easily broken.
  • Flip up the metal retaining bracket on the iSight camera cable.
  • Pull the camera cable connector straight out of its socket, toward the top of the iMac.
During disassembly, I taped the cable up and out of the way, as it tends to get in front of things.
Tony Ross - Replica
Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board. Gently push the cable out of the way. Gently push the cable out of the way.
  • Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
  • Gently push the cable out of the way.
Aggiungi Commento
Remove the following screws from the front of the logic board: Two 23.7 mm T10 screws
  • Remove the following screws from the front of the logic board:
    • Four 7.4 mm T10 screws
    • One 20.8 mm T25 spacer screw
    • One captive T10 screw
      • This screw is beneath a hole in the logic board. You'll need a fixed screwdriver or the 60 mm extension from an iFixit driver kit to reach it.
The central screw is very difficult to reach! Use a long and very thin T10 screw driver
The hard drive SATA cable can't be removed just yet, but will get in the way of removing the logic board. Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port. Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
  • The hard drive SATA cable can't be removed just yet, but will get in the way of removing the logic board.
  • Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
Aggiungi Commento
Remove two 5.7 mm T10 screws from the top of the heat sink exhaust duct.
  • Remove two 5.7 mm T10 screws from the top of the heat sink exhaust duct.
Aggiungi Commento
Tilt the logic board slightly forward. Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case. Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
  • Tilt the logic board slightly forward.
  • Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
Aggiungi Commento
When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws. You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
  • When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
  • You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
To help me line up the IO ports, I filled all the USB ports on the back with thumb drives before I screwed the Logic board back down. Worked like a charm!
Alex Grayson - Replica
Remove the four 7.5 mm T8 screws from behind the GPU on the logic board. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
  • Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
  • These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
Aggiungi Commento
Remove the bracket from behind the GPU heat sink.
  • Remove the bracket from behind the GPU heat sink.
Aggiungi Commento
Remove four black stickers from the back of the CPU heat sink.
  • Remove four black stickers from the back of the CPU heat sink.
Aggiungi Commento
Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
  • Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
Aggiungi Commento
Remove the spring plate from behind the CPU heat sink. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
  • Remove the spring plate from behind the CPU heat sink.
  • Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
Aggiungi Commento
Lift the heat sink up from the logic board. The CPU will most likely stick to the heat sink, so be careful about where you put it down. The CPU will most likely stick to the heat sink, so be careful about where you put it down.
  • Lift the heat sink up from the logic board.
  • The CPU will most likely stick to the heat sink, so be careful about where you put it down.
Aggiungi Commento
The CPU will most likely be stuck to the heat sink with thermal compound. Insert the flat end of a spudger between the CPU and heat sink. Gently pry the CPU up by slightly twisting the spudger.
  • The CPU will most likely be stuck to the heat sink with thermal compound.
  • Insert the flat end of a spudger between the CPU and heat sink.
  • Gently pry the CPU up by slightly twisting the spudger.
  • Remove the CPU from the heat sink. Be careful not to touch the contacts.
  • To install a new CPU, see our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
  • For the VRAM chips surrounding the GPU, install thermal pads or a thick thermal paste such as K5-PRO, rather than regular thermal paste.
  • Install your CPU into its socket on the board, not on the heat sink. Check the orientation and make sure it lines up correctly in the socket. Follow the instructions specific to your CPU type to apply fresh thermal paste to the surface of your CPU. Then, reinstall the heat sink over the top.
Putting the heat sync back on your new CPU is really difficult. I over tightened and borked my new CPU. Also, it's quite possible that you're going to put a great deal of stress on your Logic Board if you are putting an i7 processor in an i5 board. There is extra cooling installed on the i7 boards with bigger graphics cards. I wound up getting new logic board designed for i7 and having a repair shop do the upgrade (Which is a difficult feat in itself as it's difficult to procure Apple parts on your own). I still came out ahead over buying new or buying a used model with the full specs. But only barely. I'd highly recommend working with a friend or someone that has taken an iMac apart before. Look very carefully at how much tension and is applied on the current CPU before disassembly of the heat sync and adding a new one. Once you've done it once it's not to complicated.
Chris Bernard - Replica
Conclusione
Altre 19 persone hanno completato questa guida.
i7 processor that you can put on a Imac 2013?
andres - Replica
The thermal compound/paste that is used by Apple on the GPU and memory is less than stellar. I would highly recommend stressing the GPU Memory gap in this guide. As you can see in the images of the cooler, specifically the GPU side, apple uses a white paste compound for thermal transfer. The problem is that the cooler does not contact the memory for the GPU. Once you remove the cooler it breaks the compound in several spots, and it will never be as good as it was unless care is made, and you are aware of this prior to re-installation.
tjk4 - Replica
Furthermore, with the GTX775M and GTX780M equipped iMacs, the temperatures are already above normal without removing the cooler. If you try and push these chips with the added memory in the latest generation games you will get artifacts from overheating. Due to the gap between the memory and the cooler you are also unable to use Arctic Silver as a remedy, as the gap is too much, with the logic board being vertical. (Risking seepage down the board, which I have already seen when performing the proper fix on another iMac) The coverage and type of thermal compound Apple is using is not sufficient. In the factory state the thermal compound is centered on the memory, however only 40% of the actual module comes in contact of the memory and the cooler. What I have done on my iMac and a few others so far is use thermal tape.
tjk4 - Replica
YES, I F*&^* hate thermal tape when compared to quality compound. With this only exception, the tape is more effective than the stock compound, and it is quarantined to make 100% contact, while dissipating heat properly. I have seen a drop of 15% under heavy use on the GPU since using the tape. YOU do not want to use cheap thermal tape! Standard tape only has a 3-5 watt thermal conductivity, which is equal to or less than a standard compound. You can go through frozencpu.com and purchase Fujipoly Extreme Thermal Pads which have a rating of 11. For use on the 27" iMacs, I went with 100 x 15 x 1.5 and (2) are needed to do completely cover both sides of the memory banks on the logic board.
Please, if you remove the cooler to replace the CPU you have to be aware of the GPU and the gap involved on the memory chips, and the potential of further gaps upon re-installation.
tjk4 - Replica
Are you suggesting that you used this 11kw tape on both the GPU and the GPU Memory modules?
I brought that tape but 1.5mm is way too tall and chose not to use it after all on my 27' 2013 14,2 model. Instead used 11kw X1 Extreme Fusion paste from Master Cooler. Its non-conductive so don't have to worry about short circuits. Its also very thick so doesn't run. I used the "small pea" technique on the GPU and GPU memory dims. For the actual CPU which I upgraded from the base i5 to a i7 4771 I used the "Thin line" technique.
AW H -
Prior to improving the thermal transfer on the GPU memory I have seen elevated temperatures and graphic artifacts when pushing the graphics to the max, after doing it this way I have experienced no issues and lower temps. As a side note with all thermal tapes they have a tendency to have a shorter effective lifespan than quality compound, but I don't keep computers long enough to be concerned about it. I would suggest a 2yr replacement interval if you choose to keep it for extended timeframes.
Enjoy!
tjk4 - Replica
Please also add to guide: DO NOT USE ARTIC SILVER ON THE GPU MEMORY!, yes i know i could just edit it but i'm confident you will read this info^
Thanks Walter!
tjk4 - Replica
I'm confused...are you saying Arctic Silver 5 should not be used for replacing the thermal compound on the iMac CPU? Or are you correcting a mistake from a comment from earlier. Why would you use thermal compound on the GPU or memory?
Andrew -
Thank you tjk4.
I recently upgraded the CPU to my Late 2013 27" imac. When i took the heat sink off, thermal compound from the GPU chips was used between the heat sink and the chips. It was just a bit more of it to cover the gap you specified earlier. I got a thermal pad, the only one I could find in my country was the 6w/mK made by Arctic. It was a square pad, 50mmx50mm and 1.5mm thick. I just placed it over the entire chips and I cut just a little small square in one of the sides where no chip was present.
Problem is now my iMac kicks the fan at 1800rpm whenever I do a bit of intensive work., photoshop etc. It did not do that previously with my i5 processor nor my 21 late 2013 with IRIS gpu, using the CPU close to 100%.
bvieri - Replica
I can only guess that there may be a minor gap between the cooler and the surrounding memory chips. If you go too thick on the thermal pad for the GPU it will create a gap between the cooler and the surrounding memory modules. I had to experiment with several sizes and compounds to find the best fit. It does sound like a memory resistance due to the timing, as it would take a few more cycles for the GPU to activate the fans.
tjk4 -
Did you use the thermal tape on just the GPU memory modules or both memory and GPU itself? I made that mistake and theres no contact from the heatsink to the GPU so it overheats as the thermal pads of 1.5mm are too tall! (at least on 27" 2013 14,2 models) I had to redo mine and just used quality 11kw paste which is non-conductive so no worries of short circuiting from spillage on everything. Temps are all good now.
AW H -
I still couldn't decide which type of thermal interface I should use: thermal compound or thermal pad. However, there are some details I'd like you to tell me.
If thermal pad is chosen (for example - Fujipoly 17.0 W/mK):
- what is actual gap between GPU memory and heat sink in millimeters? Is 1,5mm thick pad ok or not?
- what is actual gap between GPU chip and heat sink in millimeters? Is non-conductive thermal compound most preferred option or thermal pad is the best choice?
If alternative thermal compound is chosen:
- How many grams of it is enough to fill all of the gaps between GPU chip/memory and heat sinks?
Thanks!
3426895 -
PART II:
Do you think the 11w pad makes for such a big difference? These are my current temps, http://autoeducare.ro/foto/screen.png
I think it is better to use a good compound and using the same amount of it, like Apple did, to fit into the sheatsink and chip space. For me it worked better the way they did it, but I did not check the GPU temps before to be able to prove it, the fans were very very silent though.
bvieri - Replica
what app did you use for system info/temps in your screenshot?
Armen M -
What are upgrade options for CPU on this late 2013 iMac 27"?
What is max/best CPU to upgrade to?
Where does one purchase the actual compatible CPU? (standard Intel CPU...boxed vs. OEM...)
Armen M - Replica
"iMac27" 2013" for CPU and GPU I used "Thermal Grizzly Hydronaut" paste and "Fujipoly extreme plus (14W/mK)" 0.5mm thick for GPU Memory.
You need 2 strips 100mm x15mm. You can buy them on ebay.
tomekpiechowiak - Replica
Don't know if the heatsink height is different for the 2015 model but .5mm was a touch too low for me. If you have a 2015 (same heatsink design as instructions here) and are going the pad route get the 1.0mm. Also you don't need two strips if you just cut the single strip on each - memory chip is 12mm x 15mm so one 100mm strip will do the job. I got K5 pro instead, probably doesnt perform as well as the pad but pads were pricey $ and didnt want to risk another not fitting.
Charles -
I have a late 2013 iMac 27 inch and want to update to a ssd and change the i5 processor to a i7 processor. What is the best ssd for mac and where can I get the newer compatible i7 processor?
Wallace - Replica
Can one use a Xeon CPU instead of i7? I got the iMac27”14,2 and was wondering if one can put a Xeon instead one of the i5 or i7 series.
Patrick Jankun - Replica
Is there a list somewhere of current (late 2017) processors that would work in the Late 2013 iMacs?
David Pfenninger - Replica
Hi,
I have made a screw sheet for this guide. It made tracking the screws a lot easier since they are almost all of a different length! Take a look and tell me what you think.
https://drive.google.com/file/d/1I88-IWC...
Vasileios Antoniadis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 56
Ultimi 30 Giorni: 314
Tutti i Tempi: 35,303
