Introduzione
Use this guide to replace or upgrade your RAM chips.
Lay your iMac front side down on a table with the lower edge facing yourself.
  • Lay your iMac front side down on a table with the lower edge facing yourself.
  • Loosen the single Phillips screw PH#2 in the center of the access door.
  • This screw is captive in the access door.
  • Remove the access door from your iMac.
Aggiungi Commento
Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
  • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
Aggiungi Commento
Grab the RAM chip by its edges and pull it straight out of its slot.
  • Grab the RAM chip by its edges and pull it straight out of its slot.
  • If two RAM chips are installed, repeat this process for the other chip.
Aggiungi Commento
Conclusione
Altre 30 persone hanno completato questa guida.
johann beda
Membro da: 13/09/2010
2.225 Reputazione
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 102
Tutti i Tempi: 19,179
