Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Introduzione
Use this guide to replace the power supply.
  • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
  • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
roberttrevellyan - Replica
Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
Dan - Replica
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
  • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
Aggiungi Commento
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
Moreau - Replica
Continue running the tool up around the top left corner. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner.
  • Continue running the tool up around the top left corner.
Aggiungi Commento
Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
  • Cut the adhesive along the top left of the display.
Aggiungi Commento
Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  • Continue along the top of the display.
  • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
In this step can I cut along the display without make any damage to the front camera?
arisnordico - Replica
Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
dv1977 - Replica
After doing the replacement the adhesive still sticks quite good enough to hold the screen in place. Maybe this isn't rock-solid, but enough for me.
Mirko - Replica
I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
Can anybody help me ? Maybe the connector cable is broken?
djfanta - Replica
Check both connectors, probably one of them not seated well
pzhivulin -
You can add a SATA SSD if you already have a PCIe SSD Factory?
kaserlik - Replica
If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the display assembly.
Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
pzhivulin - Replica
omg - forgot to switch the termal sensor from the old display...
now fan runs like crazy...
Andrei Balotescu -
Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
  • Push the tool around the top right corner of the display.
Aggiungi Commento
Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
  • Wheel the tool down along the right side of the display.
Aggiungi Commento
Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  • Finish pushing the opening tool to the bottom of the right side of the display.
  • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
Aggiungi Commento
While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
  • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
  • Set the iMac face-up on a table.
  • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
  • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
Edgar Broekema - Replica
Gently twist the plastic card sideways to create a gap between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  • Gently twist the plastic card sideways to create a gap between the display and frame.
  • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
Cassio Machado - Replica
Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac. Be sure to stop before the iSight camera, or you may damage it. Be sure to stop before the iSight camera, or you may damage it.
  • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
  • Be sure to stop before the iSight camera, or you may damage it.
Aggiungi Commento
Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
Aggiungi Commento
Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
Aggiungi Commento
Gently twist the card upward, slightly increasing the space between the display and frame. As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  • Gently twist the card upward, slightly increasing the space between the display and frame.
  • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
Aggiungi Commento
Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
  • Slide the plastic card toward the center, again stopping just before the iSight camera.
Aggiungi Commento
Wedge the plastic card back into the top left corner. Wedge the plastic card back into the top left corner.
  • Wedge the plastic card back into the top left corner.
Aggiungi Commento
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
  • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
  • Begin to lift the top of the display up from the frame.
  • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
Aggiungi Commento
While holding the display up with one hand, use the other hand to unplug the display power cable. Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  • While holding the display up with one hand, use the other hand to unplug the display power cable.
  • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
Pulling the display power cable by the wires makes me nervous..
bstaud - Replica
Use the tip of a spudger to flip up the metal retaining bracket on the display data cable. Carefully pull the display data cable from its socket on the logic board. Be sure to pull the display data cable connector straight out of its socket.
  • Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
  • Carefully pull the display data cable from its socket on the logic board.
  • Be sure to pull the display data cable connector straight out of its socket.
Sure could use a magnified picture of this connector and socket, especially the first time you go in. And it is the most critical step of the whole operation — bung it up and we’re toast.
bstaud - Replica
Hi bstaud! If you hover over the image you can click on the magnifying glass and get a large image of any guide photo. Hope that helps!
Sam Lionheart -
Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Lift the display up to a near-vertical position.
  • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
Where can I find a replacement display for my iMac?
Braydon Boyce - Replica
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
Cutting through this extra adhesive on the bottom took a bit more effort than the step and picture implied (to me). Unlike the other edges, here don't be afraid to really push the card in there to break the seal, there's nothing behind that adhesive that is breakable.
phil - Replica
cutting through the adhesive is unnecessary if it's not been opened before (outside of an apple store) there will be a tab at the end of each VHB strip that you can use to simply pull the vhb strips off.
Rory McKenna - Replica
To save a few steps and a bit of time, if you have a helper, they can hold the display at a 90° angle while you unscrew the brackets and remove/replace the hard drive rather than remove the display entirely. Also reduces the likelihood of damaging the display as you remove and handle it.
marty - Replica
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
Aggiungi Commento
Remove the following five Phillips  screws holding the lower support bracket in place: Four 3.2 mm screws
  • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
  • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Aggiungi Commento
Remove the lower support bracket from the iMac enclosure.
  • Remove the lower support bracket from the iMac enclosure.
Aggiungi Commento
Remove the following screws securing the hard drive bracket to the rear enclosure:
  • Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
    • One 9 mm T10 Torx screw.
    • One 27 mm T10 Torx screw.
Aggiungi Commento
Remove the left and right hard drive brackets from the iMac. Remove the left and right hard drive brackets from the iMac.
  • Remove the left and right hard drive brackets from the iMac.
Aggiungi Commento
The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board. Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
  • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board.
  • Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
I would advise that before removing the PSU unit and all other components from the bottom of the case that you remove the 5 screws at the bottom of the display which hold an insulation strip in place.
The guide shows this piece removed, but does not tell you how to remove it.
There will be 5, small J1000 screws. The middle one, which goes over Apple Logo is the shorter one of the 5, all others are the same length. Once this piece is gone removing the components is much easier, and chance of damage lessened.
Jeffrey Gelinas - Replica
Added to the guide. Thanks for the tip!
Jeff Suovanen -
No need to remove power board and logic board and all other components, just remove the fan and it is quite "easily" accessable to change the RAM. Just need to use the tools to remove the old RAM and carefully install the new RAM.
I just did it without removing the logic or power board
Oleksandr Trokhymchuk - Replica
Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
  • Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
Aggiungi Commento
Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
  • Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
    • In newer model iMacs these are 7.2 mm T8 Torx screws.
Aggiungi Commento
When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Tilt the power supply forward.
  • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  • Tilt the power supply forward.
When replacing the PSU (on the re-build) take care not to trap the power button cable behind it - I did...
Dave Hallett - Replica
Pull the power supply slightly up and out from the rear enclosure. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  • Pull the power supply slightly up and out from the rear enclosure.
  • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
Aggiungi Commento
Slide the power supply to the right to clear the screw posts on the rear enclosure. Slide the power supply to the right to clear the screw posts on the rear enclosure.
  • Slide the power supply to the right to clear the screw posts on the rear enclosure.
Aggiungi Commento
Rock the power supply forward and remove it from its recess in the rear enclosure. Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board. Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  • Rock the power supply forward and remove it from its recess in the rear enclosure.
  • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
Aggiungi Commento
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Flip the power supply over to access the DC power cable connection behind the logic board.
  • Flip the power supply over to access the DC power cable connection behind the logic board.
  • Squeeze the tab on the back side of the DC power cable connector and pull it straight out of its socket on the back of the logic board.
when pulled the cable, even slightly, the actual female piece that connects to the logic board came off. am i screwed?
Racheal Major - Replica
You may find it helpful to set the iMac down on its back for the next couple of steps. Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward. While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  • You may find it helpful to set the iMac down on its back for the next couple of steps.
  • Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward.
  • While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
I didn't disconnect the input cable to the power supply. Because I had the machine lying on its back throughout, I placed it on to the metal bit at the bottom of the machine instead (with a cloth to stop the metal getting scratched). The AC inlet cable was pretty tricky to get un-locked, and the PSU sat on the case fine. It didn't hinder anything else throughout the guide.
I thought from Dave’s comment that I could leave the power supply completely in place, but I was mistaken. In order to remove the hard drive assembly after you remove the center screw in it, you’ll need to at least unscrew it and the HD assembly will slip out. Like Dave said, you don’t need to unplug the AC or PSU, which I left hanging.
Getting power supply to the logic board unplugged is also tricky without unscrewing the two bottom screws. They didn’t make this part easy.
delacrj2 - Replica
Remove the power supply from the iMac.
  • Remove the power supply from the iMac.
erreur: retirer "la carte d'alimentation" et non" le disque dur" !!!!!
Moreau - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Sam Lionheart
Membro da: 18/10/2012
314.972 Reputazione
1.641 Guide realizzate
iFixit Membro di iFixit
Community
115 Membri
5.778 Guide realizzate
Great guide. My question is this however, How does one test this PSU before they replace it? I can't seem to find a PSU pinout for this particular unit (661-7111)
Stephen De Tomasi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 93
Tutti i Tempi: 2,325
