Introduzione
Use this guide to replace the headphone/microphone jacks on your iMac.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Disconnect the audio port cable by pulling its connector toward the left side of the iMac.
Peel the audio port cable off the front face of the logic board.
Altre 7 persone hanno completato questa guida.
Un commento
Does anyone know whether I can connect another audio source to this iMac's Loudspeakers - and how? From the instructions it's not obvious how to use the speakers standalone from a different source.
For context: I have broken iMac with a working LCD that I can use as a external Monitor with a HDMI controller board. I would love to use the great sound of the loudspeakers, too, somehow.
