Introduzione
Replace a broken optical drive data cable to restore disk-reading capability to your iMac.
Loosen the single Phillips screw in the center of the access door.
  • Loosen the single Phillips screw in the center of the access door.
  • This screw is captive in the access door.
  • Remove the access door from your iMac.
isn't it actually pc2-5300s ?
grze - Replica
  • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
  • Stick two suction cups to opposing corners of the glass panel.
  • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
  • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
At this stage and later handling the LCD I found thin cotton gloves helped to reduce smudges
john31 - Replica
My GPS unit's car mount suction cup worked nicely here - couldn't find any at the store and didn't want to wait for mail order!
Two cups would make it easier but one is fine if you place it in the center and are careful to pull the panel straight out.
Mathew Hendry - Replica
Why use suction cups when some finger nails will do the job nicely, though a plastic spudger might work too. Start at a top corner. Prize the glass away from the case and leave finger nails in. Move the other hand along the top edge and then with finger spread peel the screen cover away. Be careful not to twist plastic I suppose, but I've had no difficulties.
damianwise - Replica
3M Command Strip hooks in opposite corners is another fabulous option when suction cups are not available!
Adam McCombs - Replica
Tape works fine, here. Search for a YouTube video for a simple look-see.
Richard - Replica
I didn't have any suction cups, but my pencil sharpener (the kind that suctions to the table) worked great. I put it on the middle and lifted straight up.
Lisa Mac - Replica
For a quick 'n' dirty alternative "tool" for this step, take a look at IKEA's Stugvik suction hooks: they provide an excellent adjustable grip. Just used it to take apart an EMC2133. Cheers!
hadderakk - Replica
Suction cups usually available at Home Depot or Lowes, in the flooring section. (They're used to handle large ceramic & stone floor tiles.)
Griff in Fairbanks - Replica
Gently pull the glass panel straight up off the iMac.
  • Gently pull the glass panel straight up off the iMac.
  • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
  • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on. Placing the glass flat, inside face down, on a fresh aluminum-foil surface is a good way to keep it clean.
In order to avoid unnecessary smudges and what not I covered the LCD itself with some plastic wrap while doing the hard drive upgrade. When I reinstalled it all I needed to do was blow off a few dust particles.
robgendreau - Replica
While you are at it, it is worth cleaning out dust within the case to help with cooling - particularly around the fans and vents.
For the screen I used a lens cleaner from my camera bag. These have very fine fibers and won't leave detritus.
Note that the front glass panel is quite light. When reassembling I found it impossible to get the LCD free of dust with the computer lying on its back. I had success with standing the computer up, tilting the LCD down as far as it goes, holding the glass panel upright in front of the computer (about 1 foot away), lightly spraying both the LCD and the back side of the glass panel with compressed air, and then attaching the glass panel (with the computer upright). It took me 5 tries before it was completely clean of dust once the front glass was on.
axel - Replica
Remove the following 12 screws securing the front bezel to the rear case:
  • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
On the 24" EMC2134 there are 3 screw sizes: 6x13, 4x20 & 2x30mm, particular note should be made of their location.
john31 - Replica
Note for the less experienced.. the case is plastic and the metal coarse thread screws will easily cut a new thread in the hole if you don't line up the screw in the original thread. Do this a few times and the hole will be stripped and the screw no longer tightens.
TIP:- place the screw in the hole and rotate BACKWARDS/counter clockwise (for RH threads) until you hear/feel it click/drop into the original thread then tighten the screw down. rotate it a couple times to get the feel of things. If there is any significant resistance you probably don't have the original thread.
This trick also works on the fine metal thread screws and can help avoid cross threading them.
HIH
Richdave - Replica
On the 24 inch iMac Model A1225 EMC #2134, the two T8 Torx screws in the middle are the longer of the four total bottom 25 mm screws. Just a note for reassembly.
bhoffs - Replica
This step is not really explained here with pictures. But you can check this same step in another guide to help you : Installazione della mascherina anteriore nell'iMac Intel EMC 2266 da 20"
thibault - Replica
I'll echo Thibault's comment. This guide does not actually tell you when and/or how to remove the bezel! Click on the other guide he linked to see the photo and instructions.
steven - Replica
Make sure you're ram slot at the bottom is open to remove front frame bezel
edgain99 - Replica
I think you're missing this step: With the iMac lying on its back screen facing up, grasp the aluminum sides of the bezel and carefully pull it straight up. Then disconnect the microphone cable. Took me a while to figure it out.
Richard Cacciato - Replica
I found it helpful to use a few lids from spaghetti sauce jars to hold the different screws. I used a sharpie to mark the inside of the lid w/ location taken from or the step number from directions. Then I placed a small magnet under the lid to hold the screws inside the lid in case I accidentally jostle something on the table. Worked great! You can also use a magnetic knife bar to line up the lids in sequential for the project.
tom - Replica
Disconnect the microphone cable connector, removing tape as necessary.
  • Disconnect the microphone cable connector, removing tape as necessary.
  • For the front bezel to sit properly, be sure to tuck the microphone cable and connector into the void next to the camera board.
I avoided this step by just flipping the housing over and having it lay flat on the table. The tape on mine was on really tight, and I risking ripping the wires out of the connector if I messed with it (I didn't have some really small scissors which might have helped removing it). I would suggest either securing the body of the iMac and the housing to the table you're working on, or somehow securing the housing to the body, so that it doesn't move around accidentally, since it's only hanging on by a very thin wire at that point.
Make sure you do not pull this apart by the wires. Have a firm grasp on the plastic parts. Do not force back together. It only goes back together one way. Also, it is crucial when placing the aluminum bezel back in place that this wire is out of the way. It often gets in the way and is easily damaged.
Kyle Freeman - Replica
CAUTION - To disconnect the cable, you'll need to support the bezel while you carefully extract slack microphone cable which is tightly tucked within the iMac. (I didn't have this guide's 'notes on' and missed robgendreau's warning - then inadvertently shifted the bezel and busted my microphone cable in this step.)
dagnew - Replica
Don't forget to pull the microphone cord out before you put the panel back on. Otherwise you will have to go back and remove screws to find that microphone cord
Melvin Hines - Replica
As robgendreau says, avoid this whole step by opening the bezel and laying it upside down above the iMac, still connected by the mic cord, just carefully. Then replace the battery, suck/blow out your dust, and carefully rotate the front bezel back over the iMac from where you removed it. No cord manipulation or damage at all!
recmsoj - Replica
Pull the LCD temperature sensor connector straight up out of its socket on the logic board. If necessary, de-route the LCD temperature sensor cable from behind the logic board.
  • Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
  • If necessary, de-route the LCD temperature sensor cable from behind the logic board.
  • When you remove the LCD, check the routing of the LCD temperature display cable. On reinstalling the display, be sure this cable does not block one of the bottom screws for the front bezel.
This was the most confusing step, because the video shows MJ just tilting the monitor open, and I had a ribbon cable hooked up to it. Finally figured out that the ribbon cable was connected to the LCD temp sensor cable, and it was neatly tucked under the adjacent fan. Had to pull it pretty hard to get it out from under the fan, and then could tilt the LCD. Instructions are not completely clear about this, only that you may have to reroute the cable around the motherboard.
d3nn151950 - Replica
I agree, there is no sign of how to remove the bezel (it took me several minutes to understand it was even the bezel that came off here) in these steps (in all the guides for this model, in fact). On step 4 says remove the LCD screws, and suddenly step 6 shows innards and fans etc - !! - What about showing the bezel being removed here - super confusing and not up to usual ifixit high standards.
hutchwilco - Replica
If you rush through the reassembly, it's very easy to miss reconnecting the LCD Temp Display cable. I just did it and one of the fans came on full-speed and stayed there through a new macOS install. Did a Google search and found mention of this symptom. At first I was thinking I switched one or more of the inverter cables but this guide shows that this is not a problem. Once I reviewed this step, the problem was obvious as was the solution. Thanks again, iFixit, for saving my nappy behind.
barryjaylevine - Replica
Remove the two 5.3 mm T6 Torx screws securing the data display cable to the logic board.
  • Remove the two 5.3 mm T6 Torx screws securing the data display cable to the logic board.
My Torx 6 driver purchased from ifixit didn't fit the screws well and potentially would strip them. Had to purchase a better driver to fit better in order to loosen these screws.
kakisback - Replica
reinstalling these screws requires extra care to be sure you don't drop it and loose it under any of the other components.
kakisback - Replica
Make sure not to drop the screws.
ulan - Replica
Removing these screws was the most difficult part of the whole job. They were tight and felt as if the heads were about to chew up. I had to press really hard and jerk the screwdriver counter clockwise to loosen them. Despite others' warnings, I managed to drop a screw when reinserting.
kevinp - Replica
The only tool I needed to buy was the T6 Star Bit - the first auto store I went to had it. These screws are tiny so you have to be careful not to drop them!
James Miles - Replica
When reinstalling these tiny screws, consider placing the iMac upright. That way when you (inevitably) drop these tiny screws, you don't lose them in the guts of the computer where they are likely to fall into a fan.
stown1211 - Replica
Yes, this step is very difficult. I finally used a magnet to magnetize the torx driver, and that helped immensely...however, that was AFTER I lost the right one inside the computer. You really only need one screw to reattach the monitor connector, however.
Argh! I dropped my right screw into the bowels of the iMac. I can't find it anywhere and am loath to leave it rattling around as well as to tear down the machine any further.
steven macfarlane - Replica
Well, I followed the instructions for right-speaker removal and optical drive fan removal and still couldn't find the right screw. I couldn't hear it rattle either so figured it was wedged somewhere. Using an inspection mirror and flashlight, I finally found it. It had fallen down and wedged between the PCB and the plastic housing (below the ports). I was able to slide it toward the right until it came to the void left by the right speaker where it fell out into my hand.
steven macfarlane -
It's true, these were super tight. I only had a T5 which worked on the first screw, but the second wouldn't budge. Ended up filing the tip off the T5 bit - presto! - instant T6.
marcintosh - Replica
I Think the real screw size is 3.5 mm T6 Torx, not 5.3 mm
raul - Replica
Dropped those little bastards like 2-3 times into the deeps of my iMac. The right one is really tricky. If you drop it: better get yourself very thin tweezers and gently shake your mac. :(
Popelnase - Replica
Note that just below where you are working is the PRAM battery. If you have never replaced this, now is a good time so you won't have to open the machine up again in the near future. The battery is a CR2032.
mattgauntt - Replica
Taking all the warnings into account about losing these tiny screws, during removal and replacement I held onto the screws tightly with a very fine needle nose tweezer. Fortunately I managed not to lose them either out or in. I highly recommend using a small gripper during this step.
recmsoj - Replica
This step together with step 8 can be avoided. Leave this cable alone. You will have plenty of space to lift the LCD and rest it against a wall or any other object. Again...
1) don't waste your time if you know what you are doing
2) don't complicate things and remove unecessary cables.
Scorps - Replica
This is true. There's plenty of space to work without taking the whole LCD out, either by resting it on your head, having someone hold it, or propping it on something. This makes steps 7, 8, and 10 unnecessary.
hillman -
While you have the case open this would be a good time to replace the PRAM battery and carefully clean the fan and interior of the case with Q-tips / compressed air.
John Fisk - Replica
These screws are Torx 7 - at least that was what
I used on them and got a prefect tight fit ... .
Patrik Albin - Replica
torx 6 didn't do it, needed torx 7
nielsdolieslager - Replica
Torx7 did NOT work for me. Torx6 did.
pdienstm - Replica
Use the attached black tab to pull the data display cable connector away from the logic board.
  • Use the attached black tab to pull the data display cable connector away from the logic board.
Aggiungi Commento
Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case. Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
  • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
  • Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
I was able to disconnect the two connectors to the front easily. With those off, I just rotated the LCD out of the way to expose the hard drive. Again, make sure it's stabilized if you do this so that when you yank on something else you don't send it flying.
I did a HD replacement on my 24 inch iMac. It's basically the same, but it does not have disconnectable invertercables. Instead, there's just one cable that's can't be disconnected. It sits too tight to rotate the display to the degree that you can lean it against something, so the only way to get the job done was to call in an extra set of hands to hold the display while I took out the hard drive.
Marijn - Replica
On the 2134 model, I found that the LCD must be lifted from the RIGHT (not the left as per the 2133 guide) - the connector wires are covered in nylon housing and it's way easier just having someone hold the LCD vertical whilst you replace the HDD, unless you have small fingers and feel like disconnecting completely ...
simon - Replica
During reassembly, make sure that the data and temperature cables will reach their sockets before inserting the eight screws.
kevinp - Replica
With the display panel still lifted, disconnect the four inverter cables. During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
  • With the display panel still lifted, disconnect the four inverter cables.
  • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
  • During reassembly, the order of the inverter cables is interchangeable within each socket.
  • If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
Make sure to not squeeze the inverter-cables between the superdrive and the display when putting the display back on !
epzzky - Replica
This was the only step different for my 2134 - it is just one cable that connects to the monitor - disconnect the monitor end rather than the motherboard side.
Jim Laredo - Replica
There is no need to discnnect the inverter cables if display is positioned against a wall or something of the sort. Make sure it doesn't tumble over !!!
info5825 - Replica
For 24" iMacs, a single power cable is attached on the left side of the screen. To remove the cable, lift the screen from the right side and rotate it to the left. Remove the black plastic protector on the back of the screen and disconnect the cable.
Matt Stichnoth - Replica
Make sure you squeeze the two ends of the inverter cable together firmly - if not you will get yellow areas on your screen. One of my cables had not quite been clicked together, and I had to unscrew everything all over again.
Philip - Replica
So does it matter which ones are connected to which?
That is, at each end there are two connectors (one pink/black the other light blue/dark blue on the "male" side). The "female side appear identical. Does it matter if the pink/black "male" one is connected to the wrong "female" one?
Mark Gibson - Replica
Mark, did you ever get an answer about the connectors?
Mike -
Agreed this is an unspecified issue and i'm surprised it's not covered? Did everyone else just guess?
kainatticus -
Managed to avoid this step just lifting the lcd panel and holding it with my... head ;)
Antonio Bernardini - Replica
I'm trying to find some information on replacing the power supply temperature sensor cable. Mine broke during removal of a bad power supply.
Mike Overholt - Replica
found out that taking the 2 inverter cables (top right corner underneath LCD) and mixing them will not work. I got beeping sound. So...you really need to mark the 2 white sockets with P (pink) and B (for light blue-gray color). Then everything will come out smoothly. Again... inserting the 2 inverter cable sets into the right socket DOES MATTER.
Scorps - Replica
Re: Scorps comment above - I got the “beeping” too. Does anyone know how to resolve it, i.e. identify which goes with which? Other than trying every combination?
mchlgrblsk - Replica
My screen is just Grey? anyone else have this happen?
Michael McGuire - Replica
After replacing iMac’s HDD with a new one I’ve got white screen with vertical black and bluish bands on the left side and two horizontal lines dividing the display into three equal parts (see the image). Any idea what that might be?
Andrey - Replica
Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
  • Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
  • Pull the connector parallel to the face of the logic board.
Aggiungi Commento
De-route the left speaker cable from the channel in the CPU fan. Continue completely de-routing the cable through the undersides of the IR board and heat sink.
  • De-route the left speaker cable from the channel in the CPU fan. Continue completely de-routing the cable through the undersides of the IR board and heat sink.
Aggiungi Commento
Disconnect the ambient temperature sensor cable by pulling its connector straight up off the logic board.
  • Disconnect the ambient temperature sensor cable by pulling its connector straight up off the logic board.
Aggiungi Commento
Spedizione gratuita su tutti gli ordini da 79,00 US$ in su.
Sfoglia il Nostro Negozio
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
If necessary, de-route the ambient temperature sensor cable from under the power button cables.
  • If necessary, de-route the ambient temperature sensor cable from under the power button cables.
Aggiungi Commento
Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case. Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
  • Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case.
  • Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
I found it impossible to lift the speaker out without breaking the plastic mounting pin. All I can say is don't worry about it if it happens. When I put it back and tightened the screw, it seemed solidly in place.
Disconnect the power button and CPU fan by lifting their connectors straight up off the logic board.
  • Disconnect the power button and CPU fan by lifting their connectors straight up off the logic board.
Aggiungi Commento
  • Disconnect the SATA data cable from the logic board by carefully pulling it straight away from its socket.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
It is necessary to remove the stuck on plastic cover that covers the RAM sockets in order to remove the speaker and SATA cables.
Care is needed because it is easy to snap the plastic which has probably aged by the time dismantling takes place!
Steve Jagger - Replica
Pull the SATA data cable out of its channel in the logic board and tuck it aside near the left edge of the rear case.
  • Pull the SATA data cable out of its channel in the logic board and tuck it aside near the left edge of the rear case.
I’m hurting my fingers, but can’t unplug it. This sucks!
ladycerridwyn - Replica
Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board. After both locking arms pass their retaining tabs, it is helpful to push them toward the left edge of your iMac with one hand while pulling on the body of the connector with your other hand.
  • Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board.
  • After both locking arms pass their retaining tabs, it is helpful to push them toward the left edge of your iMac with one hand while pulling on the body of the connector with your other hand.
Thing won’t move!
Use the flat end of a spudger to pry both AirPort antenna connectors up off the AirPort card. Use the flat end of a spudger to pry both AirPort antenna connectors up off the AirPort card.
  • Use the flat end of a spudger to pry both AirPort antenna connectors up off the AirPort card.
Aggiungi Commento
Move both AirPort antennas toward the lower edge of your iMac, out of the way of the logic board.
  • Move both AirPort antennas toward the lower edge of your iMac, out of the way of the logic board.
Aggiungi Commento
Use the flat end of a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
  • Use the flat end of a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
Aggiungi Commento
Pull the camera cable connector straight up out of its socket on the logic board.
  • Pull the camera cable connector straight up out of its socket on the logic board.
Aggiungi Commento
Pull the right speaker cable connector straight up out of its socket on the audio board.
  • Pull the right speaker cable connector straight up out of its socket on the audio board.
Aggiungi Commento
Remove the single 12 mm T10 Torx screw securing the right speaker to the rear case. Lift the right speaker up and out of the rear case, to clear the plastic mounting pins underneath it.
  • Remove the single 12 mm T10 Torx screw securing the right speaker to the rear case.
  • Lift the right speaker up and out of the rear case, to clear the plastic mounting pins underneath it.
Aggiungi Commento
Lift the optical drive fan connector straight up out of its socket on the logic board.
  • Lift the optical drive fan connector straight up out of its socket on the logic board.
Aggiungi Commento
Use the flat end of a spudger to pry the optical drive cable clip up off the optical drive connector. Lift the optical drive cable clip off the logic board.
  • Use the flat end of a spudger to pry the optical drive cable clip up off the optical drive connector.
  • Lift the optical drive cable clip off the logic board.
  • During reinstallation, be sure the two raised bumps on the lower edge of the optical drive cable clip lock into the two voids on the underside of the optical drive socket.
Aggiungi Commento
Push the optical drive cable connector toward the top of your iMac to disconnect it from the logic board.
  • Push the optical drive cable connector toward the top of your iMac to disconnect it from the logic board.
Aggiungi Commento
Lift the microphone cable connector straight up out of its socket on the audio board.
  • Lift the microphone cable connector straight up out of its socket on the audio board.
  • During reinstallation, ensure that the mic cable runs between the ODD fan and the board support. If the cable runs on the wrong side of the support, the cable will be too short to plug in.
TIP for re installation..I had the mic cable around the left side board support when I installed the board so it was too short and had to pull the board a out again! Make sure the mic cable runs between the ODD fan and the board support.
Richdave - Replica
If necessary, remove the piece of tape securing the thermal sensor and fan cables to the chassis.
  • If necessary, remove the piece of tape securing the thermal sensor and fan cables to the chassis.
Aggiungi Commento
Disconnect the following three cables from the logic board:
  • Disconnect the following three cables from the logic board:
    • Hard drive thermal sensor.
    • Optical drive thermal sensor.
    • Hard drive fan.
  • When removing these connectors, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
Aggiungi Commento
Remove the following 13 screws securing the logic board to the rear case:
  • Remove the following 13 screws securing the logic board to the rear case:
    • Six 7.2 mm coarse-thread T10 Torx.
    • Two 6.8 mm T8 Torx. When reinstalling these two screws, don't overtighten them, as the plastic tabs they hold down are thin and brittle, and can crack.
    • Three 7 mm fine-thread T10 Torx.
    • Two 24 mm T10 Torx.
Aggiungi Commento
Lift the logic board out of the rear case, minding any cables that may get caught.
  • Lift the logic board out of the rear case, minding any cables that may get caught.
  • If the front edge of the logic board, under the RAM sockets, won't pull up, it's sticking on the three plastic mounting pins in the rear housing under this edge. Use a spudger under the front edge of the RAM sockets to gently push up on this edge until it clears these mounting pins.
Aggiungi Commento
Lift the optical drive fan up off the plastic posts protruding from the rear case.
  • Lift the optical drive fan up off the plastic posts protruding from the rear case.
Aggiungi Commento
Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
  • Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
Aggiungi Commento
Insert the flat end of a spudger between the optical drive connector and the body of the optical drive. Twist the spudger to separate the connector from the optical drive.
  • Insert the flat end of a spudger between the optical drive connector and the body of the optical drive.
  • Twist the spudger to separate the connector from the optical drive.
  • It may be necessary to work from alternating sides of the connector until it is disconnected.
Aggiungi Commento
De-route the optical drive data cable out of the rear case.
  • De-route the optical drive data cable out of the rear case.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Outstanding guide.....followed and everything went smoothly. Thanks!
subfreeq - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 8,628
