Salta al contenuto principale
iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement
  1. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement, Power On Button: passo 1, immagine 1 di 1
    • To get to the power button first remove the hard drive fan as seen in other guides.
  2. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 2, immagine 1 di 1
    • This is a picture of the button in place with the connector to the logic board removed.
    • There are three plastic pins protruding up from the main back case that the button fits over. They appear to be slightly melted and mashed to hold it in place. I used a pocket knife to pry it up and off the posts.
  3. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 3, immagine 1 di 2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 3, immagine 2 di 2
    • Here it is with the back plate of the button pried off. This exposes a white plastic washer under it.
  4. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 4, immagine 1 di 1
    • The center of the washer has a center locking pin to correctly place it on the back of the button. The washer is concave and the concave side faces the button, This gives the button a spring to it so that it will pop back out.
  5. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 5, immagine 1 di 2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 5, immagine 2 di 2
    • This is he back of the button that will now just push out. Picture #2 is with the button removed.
  6. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: passo 6, immagine 1 di 1
    • Test the button to see if it works.
    • After replacing the button, use something (like a low temperature soldering iron) that will melt the tops of the white plastic pegs to secure the button in place.
Conclusione
Altre 4 persone hanno completato questa guida.
mayer
Membro da: 01/04/10
685.280 Reputazione
12 Guide realizzate
MacHale Enterprises Membro di MacHale Enterprises
Business
1 Membro
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 13,836
