Introduzione
Replace your broken optical drive fan to keep temperatures down!
Cosa ti serve
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Lift the optical drive fan off the plastic posts protruding from the rear case.
