Introduzione
Keep your iMac cool and happy by replacing the upper right fan.
Strumenti
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
Disconnect the upper left fan cable connector from the logic board by pulling its connector straight up.
De-route the fan cable from around the edge of the logic board as necessary.
Remove the two T8 Torx screws securing the upper left fan to the chassis.
Lift the upper left fan out of the chassis.
Disconnect the upper right fan cable connector from the logic board by pulling its connector straight up.
Remove the two shouldered T8 Torx screws from the upper right fan.
Lift the fan out of the chassis, de-routing the cable as necessary.
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - Replica
That chick MJ is sexy!!!!!
djmadcracker - Replica
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - Replica
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - Replica
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - Replica
