Introduzione
iMac not reading disks anymore? Use this guide to replace your optical drive.
Cosa ti serve
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Remove the two 3.7 mm T6 Torx screws securing the optical drive connector board to the optical drive.
Altre 15 persone hanno completato questa guida.
