Introduzione
Like brain surgery? Use this guide to replace your logic board.
Cosa ti serve
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor board.
Altre 61 persone hanno completato questa guida.
