Introduzione
Replace your inverter board with this guide.
Lay the iMac display-side down on a flat surface.
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - Replica
That chick MJ is sexy!!!!!
djmadcracker - Replica
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - Replica
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - Replica
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - Replica
Lift the rear panel slightly from the bottom edge of the iMac. Pull the rear panel toward yourself and remove it from the iMac. Pull the rear panel toward yourself and remove it from the iMac.
  • Lift the rear panel slightly from the bottom edge of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
Aggiungi Commento
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
  • Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Aggiungi Commento
Lift the optical drive near the connector to separate it from the logic board. Lift the free end of the optical drive just enough to clear the fan cover.  Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel. Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
  • Lift the optical drive near the connector to separate it from the logic board.
  • Lift the free end of the optical drive just enough to clear the fan cover. Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
  • Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
  • Lift the optical drive out of your iMac.
  • When reinstalling your optical drive it may be necessary to set the bezel attached to the open end of the drive on the plastic positioning pins molded into the front bezel of the iMac and pull the connector side of the drive toward the edge of the rear case, bending it outward slightly, to properly seat the connector.
Aggiungi Commento
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
  • Slide the inverter-to-display cable connector from under the metal clip on the midplane.
Aggiungi Commento
Disconnect the inverter-to-display cable connector by pulling it straight away from its socket.
  • Disconnect the inverter-to-display cable connector by pulling it straight away from its socket.
Aggiungi Commento
Remove the single Phillips screw securing the inverter to the logic board. Lift the inverter straight up off the pins on the logic board.
  • Remove the single Phillips screw securing the inverter to the logic board.
  • Lift the inverter straight up off the pins on the logic board.
  • Be sure to lift the inverter straight up off the logic board, as the connector pins are very long and easily bent. If the pins bend during removal, use the connector on the inverter as a guide to bend them straight.
Aggiungi Commento
De-route the inverter cable connector from the channel in the logic board.
  • De-route the inverter cable connector from the channel in the logic board.
Aggiungi Commento
Disconnect the inverter cable from the logic board by pulling it straight up from its socket.
  • Disconnect the inverter cable from the logic board by pulling it straight up from its socket.
  • Replacement note: it may be helpful to carefully reattach this connector before seating the midplane assembly, making sure the connector safely passes through the hole in the midplane assembly.
Aggiungi Commento
Insert the flat end of a spudger between the plastic inverter cover and the inverter board. Run the spudger along the edge of the inverter board to free all the tabs holding the plastic inverter cover to the inverter board.
  • Insert the flat end of a spudger between the plastic inverter cover and the inverter board.
  • Run the spudger along the edge of the inverter board to free all the tabs holding the plastic inverter cover to the inverter board.
Aggiungi Commento
Lift the plastic inverter cover off the inverter board.
  • Lift the plastic inverter cover off the inverter board.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 10,421
