Introduzione
Replace the optical drive in your iMac G4 15".
Cosa ti serve
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Remove the four 28.07mm Torx #15 screws from the lower case.
Using a Torx #9 screw driver, remove the two 8.77mm screws holding the drive's shield onto your iMac G4.
Remove the drive shield from your iMac.
Altre 15 persone hanno completato questa guida.
