Introduzione
This step will help you connect to wireless internet and get you back to surfing the internet faster than before. You can add a AirPort to your computer even if it did not originally come with one.
Parti
Nessuna parte richiesta.
Place the computer monitor face down on a safe, harmless surface. Using a  Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  • Place the computer monitor face down on a safe, harmless surface.
  • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Aggiungi Commento
Remove the metal plate from bottom of the iMac G4.
  • Remove the metal plate from bottom of the iMac G4.
  • The four screws do not completely separate from the metal plate.
Aggiungi Commento
Use a spudger to lift and remove the AirPort's antenna connector.
  • Use a spudger to lift and remove the AirPort's antenna connector.
  • This step is only applicable to iMacs that came with an AirPort card installed.
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Lilly
Membro da: 11/10/2011
541 Reputazione
2 Guide realizzate
Cal Poly, Team 5-32, Amido Fall 2011 Membro di Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Membri
8 Guide realizzate
Make sure to insert the AirPort Card with the label facing down, away from you.
Nathan Larsen - Replica
Does the antennae cable not plug into the card - Your illustration shows a large cable simply taped on top of the card and, as far as I can see, a smaller thinner cable that appears to be going to the card. I have the bigger cable in my iMac but it dues not appear to fit into the card - Do Inhave the wrong card or something?
roger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,334
