Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws. Unscrew the four 11mm screws from the base. Pry the base loose using the spudger.
  • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
  • Unscrew the four 11mm screws from the base.
  • Pry the base loose using the spudger.
  • Remove the base by hand.
Aggiungi Commento
Remove the two black 6mm screws connecting the main circuit board to the housing top. Grasp front housing and back housing firmly.
  • Remove the two black 6mm screws connecting the main circuit board to the housing top.
  • Grasp front housing and back housing firmly.
  • Gently pull front housing from the back housing.
Aggiungi Commento
Follow the prerequisite guide to remove the main housing.
  • Follow the prerequisite guide to remove the main housing.
Aggiungi Commento
Remove the two 7mm screws from the circuit board
  • Remove the two 7mm screws from the circuit board
Aggiungi Commento
Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
Aggiungi Commento
Peel the glue from each of the three ribbon cable connections. Remove the solder joints from the back of each ribbon cable. Remove the ground wires by removing the solder joints on the back of the housing.
  • Peel the glue from each of the three ribbon cable connections.
  • Remove the solder joints from the back of each ribbon cable.
  • Remove the ground wires by removing the solder joints on the back of the housing.
Aggiungi Commento
Remove glue from 3 ribbon cables from circuit board using fingers Detach speaker cables from circuit board with soldering iron Remove 3 ribbon cables with soldering iron
  • Remove glue from 3 ribbon cables from circuit board using fingers
  • Detach speaker cables from circuit board with soldering iron
  • Remove 3 ribbon cables with soldering iron
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 184
