Introduzione
There are two scroll wheels on the iHome iH8BR. If you face the front of the iHome, the right scroll wheel controls the radio frequency while the left one controls the volume. These wheels can become worn down after heavy use and may need replacement.
Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface. Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it. Remove the battery cover and the batteries.
  • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
  • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
  • Remove the battery cover and the batteries.
Aggiungi Commento
Slide a spudger under the two front rubber pads to expose two hidden screws. Slide a spudger under the two front rubber pads to expose two hidden screws.
  • Slide a spudger under the two front rubber pads to expose two hidden screws.
Aggiungi Commento
Remove the following eight screws:
  • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
Aggiungi Commento
Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown. Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
  • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
  • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
  • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
  • The lower case can now be completely removed from the device!
Aggiungi Commento
Remove the four screws attaching the top of the case to the motherboard: Two 9.5 mm Phillips #2 screws near the speaker grille.
  • Remove the four screws attaching the top of the case to the motherboard:
    • Two 9.5 mm Phillips #2 screws near the speaker grille.
    • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
    • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
Aggiungi Commento
Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case. Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
  • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
  • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
    • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
    • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
  • Pull the back adapter cover off.
Aggiungi Commento
Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case. Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
  • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
  • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
    • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
    • One 4.0 mm Phillips #1 screw near the center of the adapter.
  • The iPod adapter should now be separate from the upper casing.
Aggiungi Commento
With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown. Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves. Use tweezers to remove the 6 ribbon cables.
  • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
  • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
  • Use tweezers to remove the 6 ribbon cables.
Aggiungi Commento
Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
  • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
  • You have now separated your iHome's inner workings from its protective case!
Aggiungi Commento
Remove the three 7.9 mm Phillips #1 screws holding the scroll wheel circuit board in place. Repeat for the other circuit board. Repeat for the other circuit board.
  • Remove the three 7.9 mm Phillips #1 screws holding the scroll wheel circuit board in place.
    • Repeat for the other circuit board.
Aggiungi Commento
Firmly press on the center of each scroll wheel to remove them. You have successfully removed the scroll wheels!
  • Firmly press on the center of each scroll wheel to remove them.
  • You have successfully removed the scroll wheels!
Aggiungi Commento
Conclusione
cfredric
Membro da: 17/04/2013
1 Reputazione
6 Guide realizzate
Cal Poly, Team 12-33, Amido Spring 2013 Membro di Cal Poly, Team 12-33, Amido Spring 2013
CPSU-AMIDO-S13S12G33
4 Membri
7 Guide realizzate
where do you get the scroll wheels to replace the bad ones?
bnewell0568 - Replica
Wow you can do the same thing leaving the entire unit intact by prying the wheels out from the top with a plastic pry tool. They come out pretty easily. This was still a very informative guide to disassembling the ihome.
huff08 - Replica
I pried the scroll wheel off like said above, wiped off dust grime, replaced it - and now it works perfect.
Sgk Glass - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,410
