Introduzione
This is a replacement guide for the charging dock on the iHome iH5.
Parti
Nessuna parte richiesta.
Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
Aggiungi Commento
Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
Aggiungi Commento
Remove the five 5/16 inch screws from the circuit board.
  • Remove the five 5/16 inch screws from the circuit board.
Aggiungi Commento
Flip the circuit board over. There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  • Flip the circuit board over.
  • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
Aggiungi Commento
Remove the following four screws securing the iHome iH5 charging dock.
  • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
Aggiungi Commento
Gently remove the charging dock from the iHome iH5 by pulling it up.
  • Gently remove the charging dock from the iHome iH5 by pulling it up.
Aggiungi Commento
Remove the final screws connecting the iH5 charging dock to the plastic holding platform
  • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
Aggiungi Commento
Replace the old iH5 charging dock with new iH5 charging dock.
  • Replace the old iH5 charging dock with new iH5 charging dock.
Aggiungi Commento
Conclusione
Dustin Lamb
Membro da: 13/03/2014
103 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 565
