Parti
Nessuna parte richiesta.
Remove any iPod or apple music device connected to the iHome and unplug from any power source.
  • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
  • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
Aggiungi Commento
Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic. Remove the plastic slide from its location and set it aside. These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
  • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
  • Remove the plastic slide from its location and set it aside.
  • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
  • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
  • Set the batteries aside, careful to not get them wet.
  • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
  • Apply force in the direction of the arrow shown above the word "Open" on the plastic. The plastic piece covering the watch battery should come loose.
  • Set this plastic covering aside as well.
Aggiungi Commento
Remove the following screws:
  • Remove the following screws:
    • Eight 10 mm Phillips #0
  • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
Aggiungi Commento
Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
  • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
  • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
Aggiungi Commento
Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
  • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
  • You should have visible access to most of the components inside the iHome now.
Aggiungi Commento
Conclusione
John Kraemer
Membro da: 09/10/2012
64 Reputazione
9 Guide realizzate
Cal Poly, Team 3-21, Amido Fall 2012 Membro di Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 370
