Introduzione
This guide will describe how to replace the speaker system's iPod/iPhone input.
Use your fingers to slide the battery case cover off in the direction of the arrows.
  • Use your fingers to slide the battery case cover off in the direction of the arrows.
Aggiungi Commento
Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  • Remove and discard the old batteries.
  • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
Aggiungi Commento
Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
  • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
  • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
  • Unscrew the 0.6 mm screw located in the center of the battery case.
  • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
Aggiungi Commento
Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
  • Remove the back cover carefully; there are many wires that connect it to the device.
Aggiungi Commento
Locate the iPhone/iPod input that is in the center of the console. Push the black plastic input stand to the left, and up, with your index finger.
  • Locate the iPhone/iPod input that is in the center of the console.
  • Push the black plastic input stand to the left, and up, with your index finger.
  • Use tweezers to wedge the input stand out of its slot.
Aggiungi Commento
Pull out the iPod/iPhone input with tweezers.
  • Pull out the iPod/iPhone input with tweezers.
Aggiungi Commento
Gently remove the Line In chip with tweezers.
  • Gently remove the Line In chip with tweezers.
    • Note: The Line In chip is located on the left side of the device.
Aggiungi Commento
Use scissors to cut the black, yellow, and red wires that connect the Line In chip to the iPod/iPhone input.
  • Use scissors to cut the black, yellow, and red wires that connect the Line In chip to the iPod/iPhone input.
  • Remove the old iPod/iPhone input and its associated wires.
Aggiungi Commento
Follow the instructions provided with the soldering station to preheat the gun before use.
  • Follow the instructions provided with the soldering station to preheat the gun before use.
  • Place new iPod/iPhone input wires, one by one, in their previous position on the Line In chip. Wrap a strip of soldering wire on the point of contact between the chip and input wire.
  • Use the soldering gun to melt the strip of soldering wire.
Aggiungi Commento
Use tweezers to carefully place the newly soldered Line In chip back into its original position.
  • Use tweezers to carefully place the newly soldered Line In chip back into its original position.
Aggiungi Commento
With tweezers, insert the end of the iPod/iPhone input through its designated hole.
  • With tweezers, insert the end of the iPod/iPhone input through its designated hole.
  • Note: The device has been rotated 90 degrees to the left in this picture.
  • With both thumbs, push in the black plastic input stand until it snaps into place.
Aggiungi Commento
Conclusione
Clemson, Team 3-4, Benson Fall 2014 Membro di Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 136
