Use your fingers to slide the battery case cover off in the direction of the arrows.
  • Use your fingers to slide the battery case cover off in the direction of the arrows.
Aggiungi Commento
Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  • Remove and discard the old batteries.
  • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
Aggiungi Commento
Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
  • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
  • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
  • Unscrew the 0.6 mm screw located in the center of the battery case.
  • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
Aggiungi Commento
Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
  • Remove the back cover carefully; there are many wires that connect it to the device.
Aggiungi Commento
Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device If the motherboard is at the bottom when you are looking down at the device, the LINE IN adapter should be on the left side of the back cover
  • Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device
  • If the motherboard is at the bottom when you are looking down at the device, the LINE IN adapter should be on the left side of the back cover
  • Carefully remove the LINE IN adapter using a pair of tweezers
Aggiungi Commento
Remove the black and red wires attached to  the LINE IN adapter that extend from the motherboard by cutting them with scissors
  • Remove the black and red wires attached to the LINE IN adapter that extend from the motherboard by cutting them with scissors
  • Repeat previous step for the blue and second black wire connecting the adapter to the battery case.
  • At this point, you should be able to carefully remove the entire faulty adapter and the wires.
Aggiungi Commento
Position the newly purchased LINE IN adapter and wires in place
  • Position the newly purchased LINE IN adapter and wires in place
  • Using a soldering iron and soldering wire, reattach the red and black wires that extend from the motherboard to their original position on the LINE IN adapter
  • Use the soldering iron and soldering wire again to reattach the black and blue wires that extend from the battery case to their original position on the LINE IN adapter
    • The blue wire should attach on the bottom of the battery case and the black wire on the top insertion.
  • The new LINE IN adapter should now be properly assembled in place with the wires connected to their proper location.
Aggiungi Commento
Conclusione
Amanda
Membro da: 13/10/2014
201 Reputazione
2 Guide realizzate
Clemson, Team 3-4, Benson Fall 2014 Membro di Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 297
