Introduzione
This guide will aid in properly removing the back cover of the device. Through doing this, you will have access to the internal pieces of the device and allow in further adjustments.
Parti
Nessuna parte richiesta.
Use your fingers to slide the battery case cover off in the direction of the arrows.
  • Use your fingers to slide the battery case cover off in the direction of the arrows.
Aggiungi Commento
Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  • Remove and discard the old batteries.
  • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
Aggiungi Commento
Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
  • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
  • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
  • Unscrew the 0.6 mm screw located in the center of the battery case.
  • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
Aggiungi Commento
Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
  • Remove the back cover carefully; there are many wires that connect it to the device.
Aggiungi Commento
Conclusione
Cristina Garcia
Membro da: 13/10/2014
301 Reputazione
3 Guide realizzate
Clemson, Team 3-4, Benson Fall 2014 Membro di Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 146
