Introduzione
One RAM slot will accept PC2100 or PC2700 chips up to 1 GB.
Strumenti
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
Grasp the clear plastic tab on the AirPort card and pull toward the display.
Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
Remove the four silver Phillips screws that secure the RAM shield.
Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connectors.
Altre 32 persone hanno completato questa guida.
