Salta al contenuto principale
iBook G4 12" 1.33 GHz Keyboard Replacement
Cosa ti serve
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: passo 1, immagine 1 di 2 iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: passo 2, immagine 1 di 2 iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: passo 2, immagine 2 di 2
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: passo 4, immagine 1 di 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
Conclusione
Altre 10 persone hanno completato questa guida.
Documenti Allegati
1Commento della guida
The screw is stripped. What should I do?
TheYootz Media Group - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 10,691
