Introduzione
Replace a broken LCD/Backlight with the display still attached to your iBook.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
Aggiungi Commento
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total). If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
  • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Aggiungi Commento
Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display. Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
  • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
Aggiungi Commento
Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
Aggiungi Commento
Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display. Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
Aggiungi Commento
Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
  • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
  • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
Aggiungi Commento
Lift the rear bezel off the display assembly.
  • Lift the rear bezel off the display assembly.
Aggiungi Commento
Close the display. Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
  • Close the display.
  • Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
  • Remove the large piece of tape near the right display hinge.
Aggiungi Commento
Remove the tape covering the inverter cable connector. Remove the piece of foil tape near the center of the thin metal LCD cover.
  • Remove the tape covering the inverter cable connector.
  • Remove the piece of foil tape near the center of the thin metal LCD cover.
Aggiungi Commento
Remove the Phillips screw near the right display hinge. Use the tip of a spudger to remove the small spacer under the screw you just removed.
  • Remove the Phillips screw near the right display hinge.
  • Use the tip of a spudger to remove the small spacer under the screw you just removed.
Aggiungi Commento
Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover. Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
  • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover.
  • Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
Aggiungi Commento
Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total). Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
  • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
Aggiungi Commento
Carefully remove the thin steel LCD cover.
  • Carefully remove the thin steel LCD cover.
Aggiungi Commento
Remove the long piece of tape securing the display data cable to the LCD. Disconnect the display data cable by pulling the cable away from the socket on the LCD.
  • Remove the long piece of tape securing the display data cable to the LCD.
  • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
Aggiungi Commento
Disconnect the backlight cable from the inverter.
  • Disconnect the backlight cable from the inverter.
  • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
Aggiungi Commento
Open the display. Lift the LCD out of the display assembly. Lift the LCD out of the display assembly.
  • Open the display.
  • Lift the LCD out of the display assembly.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Documenti Allegati
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 10,096
