Introduzione
Replacing the display data cable also replaces the microphone.
Cosa ti serve
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the following 4 screws on the bottom of the computer:
Two 3 mm Phillips from the left side of the computer.
One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
One 14.2 mm Phillips near the front, right corner.
Remove the following 14 screws (some models may be missing a couple of screws):
One 2.5 mm Phillips.
Six 3.5 mm Phillips.
One 4.5 mm Phillips near the sleep light with a small shaft.
Two 4.5 mm Phillips with larger shafts.
Four 5 mm Phillips
If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the large piece of tape near the lower right corner of the display.
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Remove the two pieces of tape over the display data/microphone cables near the lower edge of the display.
Altre 3 persone hanno completato questa guida.
Documenti Allegati
Un commento
STEP 47: I discovered those bezel screws are clearly NOT 1.5mm; under a high-power magnifying glass, the 1.5mm bit was very obviously too small, just barely turning an undamaged screw. However in an old Archer (radio shack) hex key set I found the second-smallest hex key was the EXACT fit for these screws. The package said 'from .050 to 3/8", so I'm guessing that the second smallest key was probably .040, (40 thousandths of an inch.)
If your screws don't come out easily the first time, try to find the correct-sized bit, because I can tell you from this experience that drilling out one of those blasted screws is not a fun job!
