Salta al contenuto principale
bObsweep Robotic Vacuum Battery Replacement
Cosa ti serve
Panoramica Video
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: passo 1, immagine 1 di 3 bObsweep Robotic Vacuum Battery Replacement, Battery: passo 1, immagine 2 di 3 bObsweep Robotic Vacuum Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: passo 2, immagine 1 di 3 bObsweep Robotic Vacuum Battery Replacement: passo 2, immagine 2 di 3 bObsweep Robotic Vacuum Battery Replacement: passo 2, immagine 3 di 3
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: passo 3, immagine 1 di 3 bObsweep Robotic Vacuum Battery Replacement: passo 3, immagine 2 di 3 bObsweep Robotic Vacuum Battery Replacement: passo 3, immagine 3 di 3
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: passo 4, immagine 1 di 3 bObsweep Robotic Vacuum Battery Replacement: passo 4, immagine 2 di 3 bObsweep Robotic Vacuum Battery Replacement: passo 4, immagine 3 di 3
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
Conclusione
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
Tatiana
Membro da: 06/28/14
737 Reputazione
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,782
