Introduzione
The step-by-step guide for removing bObi's cover and screen. For help putting bObi back together, refer to: Closing bObi's Cover Post-Repair
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Remove bObi’s front wheel to access one of the screws holding bObi together. Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
  • Remove bObi’s front wheel to access one of the screws holding bObi together.
  • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
  • Uninstall the larger screw that sits deeper in the wheel compartment.
Aggiungi Commento
Remove bObi's dustbin. Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes. Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  • Remove bObi's dustbin.
  • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
Aggiungi Commento
Lift the brush holder. To detach completely, unplug it from bObi. Remove the two screws on the dustbin contact point holder inside bObi. There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  • Lift the brush holder. To detach completely, unplug it from bObi.
  • Remove the two screws on the dustbin contact point holder inside bObi.
  • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
Aggiungi Commento
Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed. Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed. Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
Aggiungi Commento
Remove the four screws that secure bObi's screen and lift the whole piece out. Put the replacement screen in the open space.
  • Remove the four screws that secure bObi's screen and lift the whole piece out.
  • Put the replacement screen in the open space.
Aggiungi Commento
Re-install all four screws. For a tutorial on closing bObi, see: Closing bObi's Cover Post-Repair
Aggiungi Commento
Conclusione
To reassemble your device, follow the guide for closing bObi, found here: Closing bObi's Cover Post-Repair
Chelsea
Membro da: 24/09/2014
2.278 Reputazione
31 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 74
