Salta al contenuto principale
Zune Flash 2nd Generation Back Cover Replacement
Cosa ti serve
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Back Cover Replacement: passo 2, immagine 1 di 2 Zune Flash 2nd Generation Back Cover Replacement: passo 2, immagine 2 di 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Back Cover Replacement: passo 4, immagine 1 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 4, immagine 2 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 4, immagine 3 di 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Back Cover Replacement: passo 5, immagine 1 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 5, immagine 2 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 5, immagine 3 di 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
Conclusione
ybahman
Membro da: 11/01/09
139 Reputazione
4 Guide realizzate
Cal Poly, Team 9-20, Regan Fall 2009 Membro di Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,699
