Introduzione
The Zoombak's battery life weakens over time and it needs to be replace. It will no longer hold a charge. Instead of shipping it back to the company and paying to have the battery replaced, you can do it yourself if you have the right tools and the right battery. Finding the right battery was the most challenging part.
I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
Zoombak Personal GPS device
  • Zoombak Personal GPS device
Aggiungi Commento
Backside has four rubber plugs.  Remove them and find the Phillips head screws.
  • Backside has four rubber plugs. Remove them and find the Phillips head screws.
Aggiungi Commento
Use a small tip flat blade screw driver to remove the rubber plugs.
  • Use a small tip flat blade screw driver to remove the rubber plugs.
Aggiungi Commento
Plugs removed
  • Plugs removed
Aggiungi Commento
Rubber plugs
  • Rubber plugs
Aggiungi Commento
Remove the bottom cover.
  • Remove the bottom cover.
Aggiungi Commento
Old battery.  No numbers just 3.7 volt 890mAh.  Very difficult to figure out.  I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
Aggiungi Commento
The old one was swollen from being on the charger for so long.
  • The old one was swollen from being on the charger for so long.
Aggiungi Commento
The case without the battery.
  • The case without the battery.
Aggiungi Commento
New battery installed.
  • New battery installed.
Aggiungi Commento
And turn it back on, and it blinks green!  I let it run down and recharged the battery.  I get about 3 days use from it now.  Good luck!
  • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
James
Membro da: 04/10/2010
113 Reputazione
1 Guida realizzata
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - Replica
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,930
