Introduzione
When your memory card is full, you can follow these steps to install another microSD card in your iON.
Peel the rubber cover for the memory card and USB port away from the goggles. Be careful not to completely remove the cover!
  • Peel the rubber cover for the memory card and USB port away from the goggles.
  • Be careful not to completely remove the cover!
Aggiungi Commento
Push the memory card in until you hear it click. Pull your finger away.
  • Push the memory card in until you hear it click.
  • Pull your finger away.
  • If you pull your finger away too quickly, the card can completely pop out of the slot and could get lost!
  • The memory card will pop out about half way out of its slot.
Aggiungi Commento
Pull the memory card straight out of its slot. Pull the memory card straight out of its slot.
  • Pull the memory card straight out of its slot.
Aggiungi Commento
Conclusione
Eric Flores
Membro da: 31/07/2012
126 Reputazione
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,167
