Using a spudger, remove the back panel of the phone.
  • Using a spudger, remove the back panel of the phone.
Aggiungi Commento
Remove the battery and SD card from the phone. Remove the battery and SD card from the phone.
  • Remove the battery and SD card from the phone.
Aggiungi Commento
Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
  • Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
Aggiungi Commento
Remove the back piece, exposing the motherboard.
  • Remove the back piece, exposing the motherboard.
Aggiungi Commento
Flip up the three small tan clips holding the ribbons in place. Flip up the three small tan clips holding the ribbons in place. Flip up the three small tan clips holding the ribbons in place.
  • Flip up the three small tan clips holding the ribbons in place.
Aggiungi Commento
Gently slide each of the three ribbons out of the motherboard.
  • Gently slide each of the three ribbons out of the motherboard.
Aggiungi Commento
Slide the motherboard off of the ribbons detaching it from the front of the phone.
  • Slide the motherboard off of the ribbons detaching it from the front of the phone.
Excelente gráfica,gran aporte
Juan - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
Lilia Johnson
Membro da: 08/10/2014
583 Reputazione
2 Guide realizzate
USF Tampa, Team 9-5, Leahy Fall 2014 Membro di USF Tampa, Team 9-5, Leahy Fall 2014
USFT-LEAHY-F14S9G5
3 Membri
5 Guide realizzate
Zte blade a506 insert sim card problem
Ali Jaffar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 74
Tutti i Tempi: 2,695
