Introduzione
In this guide, you will learn how to remove the rumble motors located in the triggers. This task requires you to fully disassemble the triggers on the controller.
Remove the battery pack cover.
  • Remove the battery pack cover.
  • Remove batteries.
Aggiungi Commento
We recommend using a nylon spudger for this step. A metal spudger is shown. Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
  • We recommend using a nylon spudger for this step. A metal spudger is shown.
  • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
  • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Start prying the side plate off underneath the trigger, this makes it easier to disconnect the other clips connecting the side plate to the backplate.
Brandon - Replica
One you take it off, is it possible to click it back in?
Aiden Bear - Replica
As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
Brandon -
There is a hidden screw located in the middle of the controller behind the label. Use a screwdriver and punch a hole directly in the center of the label.
  • There is a hidden screw located in the middle of the controller behind the label.
  • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
  • Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
i damaged my screws. how do i get the screws out?
tenzin - Replica
wait. i just watched a video guide on ifixit's youtube channel about damaged screws. i'll try those methods.
tenzin - Replica
It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
David Loper - Replica
All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
John Dziedzic - Replica
Am I doing something wrong because I got the tool it said I needed and got the middle screw out but the others have a bump or something in the center of the screw and it won't fit.
kolton77 - Replica
The T8 is only good for the middle screw on my One S controller. The others require something bigger
Matej Skelo - Replica
These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
jhighsmith - Replica
The driver that iFixIt sells is cannulated.
jhighsmith -
where do you get this dumb ass screw driver
Jake Zweier - Replica
iFixit Store #IF145-027-3
VauWeh - Replica
You can bypass it with a 1.5mm flathead.
Marianne Sandling - Replica
Remove the backplate.
  • Remove the backplate.
Aggiungi Commento
Remove the faceplate.
  • Remove the faceplate.
Aggiungi Commento
You may let the rumble motors hang freely out of their sockets. De-solder the soldered joints while holding the red and black wires down on the top motherboard.
  • You may let the rumble motors hang freely out of their sockets.
  • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
  • De-solder the black and gray wires that are attached to the top motherboard.
  • Remove the rumble motors and set them aside.
  • Be careful while using the soldering iron not to damage other components or hurt yourself.
  • For information on how to solder, click here.
Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
Robert Rapier - Replica
like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
If you have a soldering station around i would still recommend using it.
yKekS Yzz - Replica
Unscrew the two 7mm T6 screws located near the rumble motor sockets.
  • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
Are these just T6 screws or Torx security T6 that is cannulated?
Kenan Vickstrom - Replica
Firmly grip sides of motherboard near the middle.
  • Firmly grip sides of motherboard near the middle.
  • Lift upwards while slightly wiggling the motherboard forward and backward.
  • Lifting the motherboard will require some force.
Aggiungi Commento
Remove the yellow tape holding the wires in place on the front of the controller.
  • Remove the yellow tape holding the wires in place on the front of the controller.
Aggiungi Commento
Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers.
  • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
Aggiungi Commento
Remove the trigger covers.
  • Remove the trigger covers.
Aggiungi Commento
Desolder the wires from the motherboard.
  • Desolder the wires from the motherboard.
  • Remove the rumble motors from its socket and pull the wire with it.
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Tommy
Membro da: 22/01/2015
1.141 Reputazione
8 Guide realizzate
Cal Poly, Team 20-15, Maness Winter 2015 Membro di Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membri
29 Guide realizzate
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - Replica
My right trigger won't work on gta 5 and on other games it works
Devean Velasquez - Replica
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow -
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Anthony Bembenek - Replica
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - Replica
Could you not just pull the wires?
Spencer Alty - Replica
How do you place the wires back onto the trigger rumble?
Timmy Sparkles - Replica
Where would one buy the replacement trigger motors?
Jared Thicc - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 123
Ultimi 30 Giorni: 487
Tutti i Tempi: 29,414
