Salta al contenuto principale
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
Cosa ti serve
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: passo 1, immagine 1 di 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: passo 1, immagine 2 di 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 2, immagine 1 di 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 3, immagine 1 di 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 4, immagine 1 di 3 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 4, immagine 2 di 3 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 4, immagine 3 di 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 5, immagine 1 di 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 5, immagine 2 di 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 6, immagine 1 di 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
Conclusione
Altre 49 persone hanno completato questa guida.
Weston Gilmore
Membro da: 09/25/17
1.789 Reputazione
1 Guida realizzata
Cal Poly, Team S18-G3, Forte Fall 2017 Membro di Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Membri
32 Guide realizzate
4 Commenti
i used a t8 and it worked
Rudy Bp - Replica
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - Replica
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - Replica
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 272
Tutti i Tempi: 24,425
