Introduzione
Connection on the fritz? Ping getting you down? Follow this guide to replace your Wi-Fi Board.
Cosa ti serve
To open your Xbox, you're going to have to cut or peel up this tamper-evident tape. But don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
Use the flat end of a spudger to free the clips securing the front panel to the upper case.
Remove the front panel from the rest of the upper case.
Altre 64 persone hanno completato questa guida.
53 Commenti
I think I'm going to try this. This would fix my: "I think there's a problem" error not being able scan for wifi, Id safely assume.
On top of that when I factory reset the box it gives me the error right away not even letting me bypass wireless connection and straight to hardwire.
Same here. Factory reset and made the system obsolete. Did you end up replacing the card and did it work?
has anyone figured this out?
