Salta al contenuto principale
Xbox One S All Digital Edition IR Blaster Replacement
Cosa ti serve
  1. Xbox One S All Digital Edition IR Blaster Replacement, Plastic Enclosure: passo 1, immagine 1 di 3 Xbox One S All Digital Edition IR Blaster Replacement, Plastic Enclosure: passo 1, immagine 2 di 3 Xbox One S All Digital Edition IR Blaster Replacement, Plastic Enclosure: passo 1, immagine 3 di 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition IR Blaster Replacement: passo 2, immagine 1 di 2 Xbox One S All Digital Edition IR Blaster Replacement: passo 2, immagine 2 di 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition IR Blaster Replacement: passo 3, immagine 1 di 2 Xbox One S All Digital Edition IR Blaster Replacement: passo 3, immagine 2 di 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition IR Blaster Replacement: passo 4, immagine 1 di 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition IR Blaster Replacement, IR Blaster: passo 5, immagine 1 di 2 Xbox One S All Digital Edition IR Blaster Replacement, IR Blaster: passo 5, immagine 2 di 2
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  6. Xbox One S All Digital Edition IR Blaster Replacement: passo 6, immagine 1 di 2 Xbox One S All Digital Edition IR Blaster Replacement: passo 6, immagine 2 di 2
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
Conclusione
Altre 2 persone hanno completato questa guida.
Jules Hajjar
Membro da: 10/10/19
1.531 Reputazione
8 Guide realizzate
Cal Poly, Team S12-G6, Regan Fall 2019 Membro di Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 47
Tutti i Tempi: 1,735
