Salta al contenuto principale
Xbox One Optical Drive Laser Replacement
Cosa ti serve
  1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: passo 1, immagine 1 di 1
    • Make sure the optical drive is not connected to any power source and is powered off.
    • Unscrew the four Phillips #1 screws on the top of the optical drive.
  2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: passo 2, immagine 1 di 1
    • Lift the lid off of the optical drive case, this should require little to no force.
  3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: passo 3, immagine 1 di 2 Xbox One Optical Drive Laser Replacement, Optical Drive Case: passo 3, immagine 2 di 2
    • Slide the remaining optical drive case off of the internal components.
    • Internal components often snag on these points when removing the optical drive case.
  4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: passo 4, immagine 1 di 2 Xbox One Optical Drive Laser Replacement, ZIF Connectors: passo 4, immagine 2 di 2
    • Locate the three ZIF connectors on the optical drive PCB.
    • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
    • Remove the ribbon cable from each ZIF connector.
  5. Xbox One Optical Drive Laser Replacement, PCB Screws: passo 5, immagine 1 di 1
    • Unscrew the three Phillips #0 screws mounting the PCB.
  6. Xbox One Optical Drive Laser Replacement, Moving the PCB: passo 6, immagine 1 di 1
    • Gently lift the PCB and place it to the side.
    • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
  7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: passo 7, immagine 1 di 1
    • Unscrew the three Phillips #0 screws mounting the optical drive laser.
  8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: passo 8, immagine 1 di 1
    • Lift the old optical drive laser from the unit and place in the new optical drive laser.
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 141
Tutti i Tempi: 4,279
