Introduzione
The LED sensor lights up when the sensor is connected. If the LED is unlit, the sensor module itself may be at fault.
Remove the sticker on the underside of the device.
  • Remove the sticker on the underside of the device.
  • Remove the four 3.1x7.7 mm T9 screws underneath the sticker.
  • While you're at it, remove the four 3.1x23.6 mm T9 screws beneath the sticker. Make note of the sizes and locations of the screws.
Aggiungi Commento
Remove the back panel. Remove the black panels on either side of the Kinect, and remove the 3.1x7.7 mm T9 screws underneath them. Remove the black panels on either side of the Kinect, and remove the 3.1x7.7 mm T9 screws underneath them.
  • Remove the back panel.
  • Remove the black panels on either side of the Kinect, and remove the 3.1x7.7 mm T9 screws underneath them.
Aggiungi Commento
Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly. Lift the internal assembly with the spudger. Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
  • Lift the internal assembly with the spudger.
  • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
Aggiungi Commento
Disconnect the ribbon cable between the sensor driver board and the motherboard. Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink. Remove the infrared sensor board for the Kinect.
  • Disconnect the ribbon cable between the sensor driver board and the motherboard.
  • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
  • Remove the infrared sensor board for the Kinect.
Aggiungi Commento
Conclusione
Malak Anshassi
Membro da: 22/09/2014
320 Reputazione
3 Guide realizzate
USF Tampa, Team 1-3, Hickman Fall 2014 Membro di USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 629
