Introduzione
The colour camera is used to capture visual data. It is mounted on the heat sink inside the Kinect.
Remove the sticker on the underside of the device.
  • Remove the sticker on the underside of the device.
  • Remove the four 3.1x7.7 mm T9 screws underneath the sticker.
  • While you're at it, remove the four 3.1x23.6 mm T9 screws beneath the sticker. Make note of the sizes and locations of the screws.
Aggiungi Commento
Remove the back panel. Remove the black panels on either side of the Kinect, and remove the 3.1x7.7 mm T9 screws underneath them. Remove the black panels on either side of the Kinect, and remove the 3.1x7.7 mm T9 screws underneath them.
  • Remove the back panel.
  • Remove the black panels on either side of the Kinect, and remove the 3.1x7.7 mm T9 screws underneath them.
Aggiungi Commento
Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly. Lift the internal assembly with the spudger. Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
  • Lift the internal assembly with the spudger.
  • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
Aggiungi Commento
Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case. Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
  • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
  • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
Aggiungi Commento
Disconnect the ribbon cable between the sensor driver board and the motherboard. Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink. Remove the infrared sensor board for the Kinect.
  • Disconnect the ribbon cable between the sensor driver board and the motherboard.
  • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
  • Remove the infrared sensor board for the Kinect.
Aggiungi Commento
Detach the ribbon cable leading to the microphone with the tweezers. Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly. Remove the stand.
  • Detach the ribbon cable leading to the microphone with the tweezers.
  • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
  • Remove the stand.
Aggiungi Commento
Remove the eight 3.0x7.6 mm T9 screws from the motherboard. Peel away the plastic film from the motherboard using the spudger. Detach the ribbon cable leading to the color camera using the spudger.
  • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
  • Peel away the plastic film from the motherboard using the spudger.
  • Detach the ribbon cable leading to the color camera using the spudger.
Aggiungi Commento
Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible. Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible. Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
  • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
Aggiungi Commento
Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way. Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way. Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way.
  • Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way.
Aggiungi Commento
Using the T5 screwdriver, remove the four 1.9x10.2 mm screws from the four corners of the camera. With the spudger inserted in between the camera and the metal casing, carefully prop up the camera.
  • Using the T5 screwdriver, remove the four 1.9x10.2 mm screws from the four corners of the camera.
  • With the spudger inserted in between the camera and the metal casing, carefully prop up the camera.
Aggiungi Commento
Conclusione
Malak Anshassi
Membro da: 22/09/2014
320 Reputazione
3 Guide realizzate
USF Tampa, Team 1-3, Hickman Fall 2014 Membro di USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 938
