Introduzione
The front panel board hosts several components: connectors for the exterior buttons, LED button lighting, Wi-Fi antenna interconnect connector, speaker connector, and IR receiver.
To open your Xbox, you're going to have to cut or peel up this tamper-evident tape. This will probably void your warranty. Have fun!
  • To open your Xbox, you're going to have to cut or peel up this tamper-evident tape. This will probably void your warranty. Have fun!
In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
Dustin D'Amour - Replica
Stickers are illegal!?
Brandon -
Thank you so much for sharing such useful information with us.I will definitely share this with my friends on essay writing service feedback .They will surely love this.Well done!
1G���Q�
ThelmaBass - Replica
every time i finish my www.rushmyessays.co.uk i play games on the xbox. i would definitely go for the fan exchage because i think mine has started making strange noises. thank you for posting with this
CrystalVaughn - Replica
For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
Kelton Stewart - Replica
Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port. The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
  • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
  • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
great guide for Xbox users, really enjoyed reading this material here online. really happy to see how things have been better and best specially in availing papersowl reviews. Thanks to all the creators.
Tammi Sherrer - Replica
There is a small plastic tab that reinforces the front corner of the Xbox. Slide the tab straight back and remove it.
  • There is a small plastic tab that reinforces the front corner of the Xbox.
  • Slide the tab straight back and remove it.
Do u sell that plastic tag I need it
Brandon - Replica
Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
B.L. Spence - Replica
Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening. There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
  • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
  • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
  • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
Aggiungi Commento
The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox. Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
  • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
  • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
Aggiungi Commento
Keep moving along the rear of the Xbox, prying up clips. Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
  • Keep moving along the rear of the Xbox, prying up clips.
  • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
Aggiungi Commento
Keep popping clips. It may help to slide the plastic opening tool across the clips. By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
  • Keep popping clips. It may help to slide the plastic opening tool across the clips.
  • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
Aggiungi Commento
Starting with the spudger you left in the crack, pry the upper case up to free the last few clips. Use a plastic opening tool to pop any straggler clips that weren't freed. Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
  • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
  • Use a plastic opening tool to pop any straggler clips that weren't freed.
  • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
  • Lift the upper case slightly and shift it to give access to the front panel board.
Aggiungi Commento
The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it. Use tweezers to lift the plastic retaining loop over the connector on the board. Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
  • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
  • Use tweezers to lift the plastic retaining loop over the connector on the board.
  • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
Aggiungi Commento
Use tweezers to pull the cable straight out of the connector on the board. Remove the upper case.
  • Use tweezers to pull the cable straight out of the connector on the board.
  • Remove the upper case.
Aggiungi Commento
The next 4 steps are directions for reassembly. Skip them to continue with disassembly. Use the flat end of a spudger to free the clips securing the front panel to the upper case. Remove the front panel from the rest of the upper case.
  • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
  • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
  • Remove the front panel from the rest of the upper case.
Aggiungi Commento
Replace the top part of the upper case. Line up the clips and press firmly to re-seat them around the perimeter. Line up the clips and press firmly to re-seat them around the perimeter.
  • Replace the top part of the upper case.
  • Line up the clips and press firmly to re-seat them around the perimeter.
Aggiungi Commento
Support the front panel near the front of the Xbox. Use tweezers to replace the front button cable in its ZIF socket. Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
  • Support the front panel near the front of the Xbox.
  • Use tweezers to replace the front button cable in its ZIF socket.
  • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
Aggiungi Commento
The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case. With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case. Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
  • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
  • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
  • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
Aggiungi Commento
Gently pull up on the speaker cable connector to disconnect it from the front panel board. Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely. Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
  • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
  • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
  • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
Aggiungi Commento
Remove the two 9.5 mm T9 Torx screws from the WI-Fi board. Lift the Wi-Fi board straight up from its socket in the upper metal case. Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
  • Remove the two 9.5 mm T9 Torx screws from the WI-Fi board.
  • Lift the Wi-Fi board straight up from its socket in the upper metal case.
  • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
Aggiungi Commento
Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
  • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
Two of the 8 were stripped even before attempting to remove….ugggh
Michael Massaro - Replica
Lift—but do not remove—the upper metal case. The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
  • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
Aggiungi Commento
Disconnect the Wi-FI board interconnect cable from the motherboard. Remove the upper metal case.
  • Disconnect the Wi-FI board interconnect cable from the motherboard.
  • Remove the upper metal case.
Aggiungi Commento
Disconnect the hard drive SATA power and data cables from the motherboard. Disconnect the hard drive SATA power and data cables from the motherboard. Disconnect the hard drive SATA power and data cables from the motherboard.
  • Disconnect the hard drive SATA power and data cables from the motherboard.
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Taiji Saotome - Replica
Lift and remove the hard drive tray from the Xbox.
  • Lift and remove the hard drive tray from the Xbox.
Aggiungi Commento
Disconnect the optical drive power and SATA data cables from the motherboard. Disconnect the optical drive power and SATA data cables from the motherboard. Disconnect the optical drive power and SATA data cables from the motherboard.
  • Disconnect the optical drive power and SATA data cables from the motherboard.
Aggiungi Commento
Remove the optical drive assembly from the Xbox.
  • Remove the optical drive assembly from the Xbox.
Aggiungi Commento
Lift the motherboard assembly out of the lower case.
  • Lift the motherboard assembly out of the lower case.
Aggiungi Commento
Remove the three 9.5 mm T9 Torx screws securing the front panel board.
  • Remove the three 9.5 mm T9 Torx screws securing the front panel board.
Aggiungi Commento
Disconnect the front panel board from its socket in the front of the motherboard.
  • Disconnect the front panel board from its socket in the front of the motherboard.
Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Andrew Optimus Goldberg
Membro da: 17/10/2009
376.028 Reputazione
1.296 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
6.002 Guide realizzate
Hi would you know where I could get that panel from that reienforces my consol
Nelson okanee - Replica
Also my button won't work to sync a new controller what part do I get to fix that
I did all that. Put it back together, now i push my power button and it only lights up for a second then dies. The power box and source are good. What did i do wrong?
Chris Chapman - Replica
My Xbox turns on and immediately turns back off pls help
gavin moyer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 146
Ultimi 30 Giorni: 751
Tutti i Tempi: 33,682
