Salta al contenuto principale
Xbox 360 Wireless Controller Rear Case Replacement
Cosa ti serve
  1. Xbox 360 Wireless Controller Rear Case Replacement, Battery: passo 1, immagine 1 di 2 Xbox 360 Wireless Controller Rear Case Replacement, Battery: passo 1, immagine 2 di 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Rear Case Replacement, Rear Case: passo 2, immagine 1 di 1
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Rear Case Replacement: passo 3, immagine 1 di 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Rear Case Replacement: passo 4, immagine 1 di 2 Xbox 360 Wireless Controller Rear Case Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $2.99
    Compra
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Rear Case Replacement: passo 5, immagine 1 di 2 Xbox 360 Wireless Controller Rear Case Replacement: passo 5, immagine 2 di 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Rear Case Replacement: passo 6, immagine 1 di 2 Xbox 360 Wireless Controller Rear Case Replacement: passo 6, immagine 2 di 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
Conclusione
Altre 22 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
127.897 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 50
Tutti i Tempi: 23,263
