Introduzione
Cracked controller case? Tired of a solid color? Bring new life to your Xbox 360 controller with a new front case.
Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
  • Depress the battery release button on the top of the controller.
  • Remove the battery holder from the controller.
  • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
Aggiungi Commento
  • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Aggiungi Commento
Remove the seven 9.3 mm  T8 Security Torx screws securing the rear case to the front case.
  • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
Any recommendation on which set of Security Torx tools to use? I've already purchased 2 kits, one of those being sold as "Xbox controller tools" but the diameter of the head does not fit the hole on the controller and that's critical for the 2 screws on the bottom. The tools must obviously be thinner in diameter and long enough to get there.
Arnie - Replica
How to open an XBOX 360 controller without a special screwdriver. http://www.instructables.com/id/How-to-o... Works perfectly.
Louis - Replica
A lot of thanks for your comment. It's very usefull
Echedey -
I picked up a handy torx key set from Auto Zone. Was about $10, no lose driver bits. has both sizes you need to repair the controller and the console. Here's the link:
http://www.autozone.com/autozone/accesso...
FierDancr - Replica
It doesn't really matter which set of bits you by or what brand makes them, Torx bits (and the security versions of them) are generic & come in standardized sizes. You do not need a special "xbox" tool kit, you just need a size 8 torx security bit, no matter what brand makes the bit/kit. Those types of "specialty kits" are usually just collections of generic bits that you can buy at a hardware store in a regular bit set. The difference is that a general bit set will have bits for screws that a specific item doesn't have in it, whereas a specialty kit will only include bits for the types & sizes of fasteners used in the specified item.
BTW, with the smaller sizes of torx security bits you can try breaking off the little post in the middle with needlenose pliers or something else that can fit in the there. Even if the post doesn't break off cleanly, it's usually short enough to fit a regular (non security) torx bit in the slot.
Nerfbomb - Replica
  • Insert a Spudger between the front and rear cases along the left edge of the controller.
  • Rotate the spudger toward the front of the controller, prying the two cases apart.
Aggiungi Commento
Insert a spudger between the front and rear cases, near the headphone jack. Rotate the spudger toward the front of the controller to pry the two cases apart.
  • Insert a spudger between the front and rear cases, near the headphone jack.
  • Rotate the spudger toward the front of the controller to pry the two cases apart.
Aggiungi Commento
Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
  • Grasp the controller by the battery compartment and the headphone jack.
  • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
  • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
Aggiungi Commento
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board. Lift the vibration motor out of the front case.
  • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
  • Lift the vibration motor out of the front case.
Aggiungi Commento
Remove the vibration motor from the other side of the controller using the same method previously described. The right motor has significantly more counterweight than the left motor.
  • Remove the vibration motor from the other side of the controller using the same method previously described.
  • The right motor has significantly more counterweight than the left motor.
The opposite was true for the controller I just opened. It was the left motor counterweight (as you hold the controller normally) which had more weight. Perhaps it doesn't matter which goes where?
Bob S - Replica
Lifting from the headphone jack and power plug, remove the logic board from the front case. Lifting from the headphone jack and power plug, remove the logic board from the front case.
  • Lifting from the headphone jack and power plug, remove the logic board from the front case.
What if you're having difficulty taking the logic board out?
Xander Uchida - Replica
In my experience with my controller, the logic board lifts out very easily, there are no tabs or fasteners holding it in.
So, if you're having difficulty taking the logic board out, call a friend with average hand dexterity & motor skills to do it for you.
Nerfbomb - Replica
Lift the bumper panel off of the front case. Lift the bumper panel off of the front case.
  • Lift the bumper panel off of the front case.
Aggiungi Commento
Remove the rubber pad from the back of the D-pad.
  • Remove the rubber pad from the back of the D-pad.
Aggiungi Commento
Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
  • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
Aggiungi Commento
The D-pad is secured to its backing by two diagonal clips, shown in red. Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
  • The D-pad is secured to its backing by two diagonal clips, shown in red.
  • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
Aggiungi Commento
Lift the D-pad backing out of its compartment on the front case. The D-pad remains below the front case.
  • Lift the D-pad backing out of its compartment on the front case.
  • The D-pad remains below the front case.
  • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
  • The backing is slotted to its compartment to ensure that it will always be aligned properly.
Aggiungi Commento
Remove the rubber pad from the back of the input buttons.
  • Remove the rubber pad from the back of the input buttons.
Aggiungi Commento
Using a pair or tweezers, remove the following buttons from the front panel: A Button
  • Using a pair or tweezers, remove the following buttons from the front panel:
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
Aggiungi Commento
Using a pair of tweezers, remove the LED ring from the front panel.
  • Using a pair of tweezers, remove the LED ring from the front panel.
Aggiungi Commento
Insert a spudger between the lower panel and front case. Slide the spudger along the gap between the two case components. Lift the lower panel off of the front case.
  • Insert a spudger between the lower panel and front case.
  • Slide the spudger along the gap between the two case components.
  • Lift the lower panel off of the front case.
Aggiungi Commento
Conclusione
Altre 14 persone hanno completato questa guida.
Brett Hartt
Membro da: 12/04/2010
106.152 Reputazione
324 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
5.999 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 39
Tutti i Tempi: 11,183
