Introduzione
There is no such thing as too much hard drive space, and nothing more frustrating than too little. This guide will show you how to replace your Xbox 360 S hard drive.
Strumenti
Nessun attrezzo richiesto.
Orient the Xbox 360 S so that the bottom of the console is facing toward you. Push the latch holding down the hard drive cover to the left. Pull the hard drive cover away from the console.
  • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
  • Push the latch holding down the hard drive cover to the left.
  • Pull the hard drive cover away from the console.
Aggiungi Commento
Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive. Pull the hard drive straight out of the console. The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
  • Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive.
  • Pull the hard drive straight out of the console.
  • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
yamboboy - Replica
You will still have your saves and account if you replace your hard drive in the new xbox
Robert Miller -
hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
Cesar Tourreilles - Replica
Conclusione
Altre 72 persone hanno completato questa guida.
Brett Hartt
Membro da: 12/04/2010
106.143 Reputazione
324 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
5.997 Guide realizzate
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Replica
10100101001011001010101010010111111111111111101001010010101010101001000101001011001010
allloa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 60
Ultimi 30 Giorni: 306
Tutti i Tempi: 116,204
