Salta al contenuto principale
Wii Balance Board Foot Replacement
Cosa ti serve
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: passo 1, immagine 1 di 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: passo 2, immagine 1 di 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: passo 3, immagine 1 di 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: passo 4, immagine 1 di 1
    • Repeat steps two and three on the remaining four feet.
Conclusione
Cory Olson
Membro da: 09/29/14
891 Reputazione
4 Guide realizzate
Cal Poly, Team 13-8, Forte Fall 2014 Membro di Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Membri
15 Guide realizzate
2 Commenti
I am in need of a foot cover. Where can I find one??
Marvin Hopper - Replica
This manual did not help
nbrown1959.nb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,913
